Rendering issue has me puzzled... AE is not rendering fields and HD to SD Resize in output module not working
Jason Lyons
on May 12, 2014 at 6:48:41 pm
I have an HD comp that I have setup to render as Upper Field in render settings and set to resize to SD and crop, effectively creating a 720x486 D1 raster - upper field (to match sources sent to me). Just last week I was able to render this and the resulting file was exactly what I asked for, however over the weekend all I am getting are Progressive files which are resized, but not cropped.
So far I have rebooted, uninstalled AE and re-installed and tried again, the rendered files are still rendering without fields and without cropping.
Anyone seen this, anyone have any suggestions? At this point I am wondering if the project is corrupt ....
Any help would be appreciated.
Best,
jason
Dave LaRonde
Re: Rendering issue has me puzzled... AE is not rendering fields and HD to SD Resize in output module not working
on May 12, 2014 at 9:08:59 pm
It sounds like it's more likely that the incorrect Render Settings & Output Module are being used.... no clue why AE would do that, though.
Dave LaRonde
Promotion Producer
Todd Kopriva
on May 13, 2014 at 8:34:53 pm
Show a screenshot of your render settings and output module settings.
After Effects team blog
