preview query
chris brett
preview query
on May 11, 2014 at 3:16:01 pm
Hi
-----------have a very complex comp with extremely long render and preview times.
----- this causes problems making animation adjustments as AE automaticaly updates preview whenever I do anything which means its taking a very long time indeed to implement a few final tweaks.
Anyone know if there is a setting please which gives the option to specify when AE updates preview --
---- seen 'live update' but want application to wait for request......
------------------------- chris --
Brian Charles
Re: preview query
on May 11, 2014 at 3:53:16 pm
Depending on what you're doing:
1: Change settings under Fast Previews to Wireframe.
2: Press Caps Lock on the keyboard to prevent the Comp Viewer from refreshing until the Caps Lock is released.
3: Under Fast Preview preferences change the Adaptive Resolution Limit to 1/16.
4: Turn on Draft 3D so that lights/shadows etc are not calculated.
chris brett
Re: preview query
on May 11, 2014 at 4:34:55 pm
thanks Brian - much appreciated
- theres a couple there I hadnt thought of - the caps button is probably the answer - dont know how that one escaped me !
.......... suppose I was also wondering if there was a 'magic' setting somewthere ......
------------------- cheers ---------------c-
