AE crashes when opening project
rikard lassenius
on May 9, 2014 at 3:23:09 pm
Since of yesterday AE started crashing when opening a project which i worked on a few weeks ago.
We opened it on a PC, saved, with a new name. and it would open just fine. When reconnecting the files (AI-drawing) it crashed again. Renamed the drawing and replaced the originals with the new ones, layer by layer. Everything worked ok.
Just now, same thing, can't open any of the versions of the project. And it gives a warning saying that it crashed when opening windows. Do you want to open those windows again? Some versions of the project, i can open when clicking no. other crash anyway. What the heck is going on?
Others open fine, but this not. It involves some puppet tools scripts that i bought from aescripts...
I'm running a new Mac Pro, with the latest version of Mavericks, and latest version of AE.
Process: After Effects [488]
Path: /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/MacOS/After Effects
Identifier: com.adobe.AfterEffects
Version: 12.2 (12.2)
Code Type: X86-64 (Native)
Parent Process: launchd [193]
Responsible: After Effects [488]
User ID: 501
Date/Time: 2014-05-09 18:23:39.073 +0300
OS Version: Mac OS X 10.9.2 (13C1021)
Report Version: 11
Anonymous UUID: 54D14E8C-AAA4-87E4-1B62-F54E0133DECE
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000845
VM Regions Near 0x845:
__TEXT 0000000100000000-0000000100004000 [ 16K] r-x/rwx SM=COW /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/MacOS/After Effects
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 BEE.dylib 0x000000010127e703 BEEp_FlattenLayerParamFunc(TDB_ParamLayerStream const*, bool) + 67
1 TDB.dylib 0x000000010251fbbe TDB_ParamLayerStream::GetFlattenedReserved0() const + 62
2 TDB.dylib 0x0000000102502ccf TDB_Stream::Write(SLU_File*) const + 1519
3 TDB.dylib 0x0000000102517f30 TDB_StreamGroup::Write(SLU_File*) const + 992
4 FLT.dylib 0x00000001019f9228 FLT_FCSeqSpec::Write(SLU_File*) const + 1688
5 TDB.dylib 0x0000000102517f30 TDB_StreamGroup::Write(SLU_File*) const + 992
6 TDB.dylib 0x0000000102517f30 TDB_StreamGroup::Write(SLU_File*) const + 992
7 BEE.dylib 0x000000010124ba08 BEE_Layer::WritePlus(SLU_File*, BEEp_FileInfo*) + 168
8 BEE.dylib 0x000000010125c615 BEE_ReattachAllItems() + 6517
9 BEE.dylib 0x00000001011243fc int LIST_ForEachT > >(std::vector >*, long, int (*)(std::vector >*, long, int, std::vector >::value_type), int*) + 76
10 BEE.dylib 0x000000010124c7c4 BEEp_WriteItemFunc(void*, BEE_Item*, BEE_FolderItem*, int) + 1988
11 BEE.dylib 0x0000000101197995 BEE_ForEachItem(BEE_Project*, BEE_FolderItem*, int (*)(void*, BEE_Item*, BEE_FolderItem*, int), void*, int) + 261
12 BEE.dylib 0x000000010124c40a BEEp_WriteItemFunc(void*, BEE_Item*, BEE_FolderItem*, int) + 1034
13 BEE.dylib 0x000000010119f4b6 BEE_GetDefaultFolder(BEE_Project*, int, unsigned char) + 2038
14 BEE.dylib 0x0000000101197995 BEE_ForEachItem(BEE_Project*, BEE_FolderItem*, int (*)(void*, BEE_Item*, BEE_FolderItem*, int), void*, int) + 261
15 BEE.dylib 0x0000000101256a4e BEE_SaveProject(BEE_Project*, unsigned int, unsigned int, int, int, int, int, BEE_ActiveItemInfo const*, std::set, std::allocator > const*, FILE_Spec*) + 5198
16 com.adobe.AfterEffectsLib.framework 0x0000000100707605 CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 309
17 com.adobe.AfterEffectsLib.framework 0x0000000100708ff7 CPDir::DoSave(int) + 55
18 com.adobe.AfterEffectsLib.framework 0x0000000100709197 CPDir::DoSaveAs(FILE_Spec*) + 183
19 com.adobe.AfterEffectsLib.framework 0x00000001002bb765 TestEmergencyUnhandledExceptionHandler() + 293
20 com.adobe.AfterEffectsLib.framework 0x00000001002bb3de SetupEmergencyUnhandledExceptionHandler(bool) + 542
21 U.dylib 0x0000000102f8071a Up_InvokeUnhandledExceptionOrHardwareErrorHandler() + 74
22 U.dylib 0x0000000102fbe8a2 SetupHardwareExceptionHandling(bool) + 418
23 com.adobe.dvacore.framework 0x00000001034f7041 (anonymous namespace)::SignalHandler(int, __siginfo*, void*) + 337
24 libsystem_platform.dylib 0x00007fff8fd2b5aa _sigtramp + 26
25 PIN.dylib 0x00000001021c99e1 std::vector<_t_PDOCG*, std::allocator<_t_PDOCG*> >::_M_insert_aux(__gnu_cxx::__normal_iterator<_t_PDOCG**, std::vector<_t_PDOCG*, std::allocator<_t_PDOCG*> > >, _t_PDOCG* const&) + 465
26 PIN.dylib 0x00000001021c830b PDFLayerOCG::_GetBounds(_t_ASFixedRect&) const + 299
27 PIN.dylib 0x00000001021be016 D_YMp_GetBounds + 1270
28 PIN.dylib 0x00000001021bdb74 D_YMp_GetBounds + 84
29 PIN.dylib 0x00000001021c3b27 D_YM_NewSeqSpecFromFile + 3847
30 PIN.dylib 0x00000001021c4df2 D_YM_SynchSeqSpec + 1586
31 PIN.dylib 0x0000000102086c38 PINp_SynchSeqSpec + 840
32 PIN.dylib 0x000000010203c05e PIN_FinishPartialRead + 1166
33 PIN.dylib 0x000000010203c4a5 PIN_ReadSeqSpec + 1013
34 BEE.dylib 0x000000010124f357 BEEp_ReadItemChunk(BEEp_FileInfo*, SLU_ChunkInfo const*, BEE_FolderItem*, M_Ratio const*, BEE_Item**, unsigned char, BEE_Project*) + 2103
35 BEE.dylib 0x00000001012516fc BEEp_ReadOneItem(BEEp_FileInfo*, SLU_ChunkInfo*, BEE_FolderItem*, unsigned char, BEE_Project*, bool) + 140
36 BEE.dylib 0x000000010125160a BEEp_ReadItems(BEEp_FileInfo*, SLU_ChunkInfo*, BEE_FolderItem*, unsigned char, BEE_Project*) + 74
37 BEE.dylib 0x0000000101250d9b BEEp_ReadItemChunk(BEEp_FileInfo*, SLU_ChunkInfo const*, BEE_FolderItem*, M_Ratio const*, BEE_Item**, unsigned char, BEE_Project*) + 8827
38 BEE.dylib 0x00000001012516fc BEEp_ReadOneItem(BEEp_FileInfo*, SLU_ChunkInfo*, BEE_FolderItem*, unsigned char, BEE_Project*, bool) + 140
39 BEE.dylib 0x000000010125160a BEEp_ReadItems(BEEp_FileInfo*, SLU_ChunkInfo*, BEE_FolderItem*, unsigned char, BEE_Project*) + 74
40 BEE.dylib 0x0000000101250d9b BEEp_ReadItemChunk(BEEp_FileInfo*, SLU_ChunkInfo const*, BEE_FolderItem*, M_Ratio const*, BEE_Item**, unsigned char, BEE_Project*) + 8827
41 BEE.dylib 0x00000001012516fc BEEp_ReadOneItem(BEEp_FileInfo*, SLU_ChunkInfo*, BEE_FolderItem*, unsigned char, BEE_Project*, bool) + 140
42 BEE.dylib 0x000000010125160a BEEp_ReadItems(BEEp_FileInfo*, SLU_ChunkInfo*, BEE_FolderItem*, unsigned char, BEE_Project*) + 74
43 BEE.dylib 0x0000000101250d9b BEEp_ReadItemChunk(BEEp_FileInfo*, SLU_ChunkInfo const*, BEE_FolderItem*, M_Ratio const*, BEE_Item**, unsigned char, BEE_Project*) + 8827
44 BEE.dylib 0x00000001012516fc BEEp_ReadOneItem(BEEp_FileInfo*, SLU_ChunkInfo*, BEE_FolderItem*, unsigned char, BEE_Project*, bool) + 140
45 BEE.dylib 0x0000000101253f48 BEEp_LoadProject(FILE_Spec*, BEE_FolderItem*, unsigned char, unsigned char, unsigned char*, BEE_ActiveItemInfo*, unsigned int*, BEE_Project*) + 8424
46 BEE.dylib 0x0000000101251d1f BEE_LoadProject(FILE_Spec*, BEE_FolderItem*, unsigned char, unsigned char, unsigned char*, BEE_ActiveItemInfo*, unsigned int*, BEE_Project*) + 175
47 BEE.dylib 0x000000010114804c BEE_Idle() + 476
48 BEE.dylib 0x00000001013239f5 BEEp_DoTask + 69
49 BEE.dylib 0x0000000101147a17 BEE_DoCommand(short, BEE_CommandInfo*) + 567
50 com.adobe.AfterEffectsLib.framework 0x0000000100705e4a CPDir::OpenFileSpec(FILE_Spec**, unsigned char, unsigned char, unsigned char) + 474
51 com.adobe.AfterEffectsLib.framework 0x000000010024afce CEggApp::OpenDocumentGuts(FILE_Spec**, unsigned char, unsigned char, unsigned char) + 414
52 com.adobe.AfterEffectsLib.framework 0x000000010024b52f CEggApp::OpenDocument(FILE_Spec**, unsigned char, unsigned char, unsigned char) + 383
53 com.adobe.AfterEffectsLib.framework 0x00000001000ab68a GetAECocoaApplication() + 5978
54 com.apple.AppKit 0x00007fff9302c0e5 __69-[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:]_block_invoke + 1651
55 com.apple.AppKit 0x00007fff92e27c23 __78-[NSDocumentController(NSInternal) _autoreopenDocumentsWithCompletionHandler:]_block_invoke_2 + 140
56 com.apple.AppKit 0x00007fff92e2780d -[NSDocumentController(NSInternal) _autoreopenDocumentsWithCompletionHandler:] + 746
57 com.apple.AppKit 0x00007fff92c92b7b -[NSApplication _reopenWindowsAsNecessaryIncludingRestorableState:registeringAsReady:completionHandler:] + 323
58 com.apple.AppKit 0x00007fff9302b9e9 -[NSApplication(NSAppleEventHandling) _handleAEOpenDocumentsForURLs:] + 306
59 com.apple.AppKit 0x00007fff92c9243b -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 450
60 com.apple.Foundation 0x00007fff8e8fef0a -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 294
61 com.apple.Foundation 0x00007fff8e8fed7d _NSAppleEventManagerGenericHandler + 106
62 com.apple.AE 0x00007fff9797ae1f aeDispatchAppleEvent(AEDesc const*, AEDesc*, unsigned int, unsigned char*) + 381
63 com.apple.AE 0x00007fff9797ac32 dispatchEventAndSendReply(AEDesc const*, AEDesc*) + 31
64 com.apple.AE 0x00007fff9797ab36 aeProcessAppleEvent + 315
65 com.apple.HIToolbox 0x00007fff8dab7161 AEProcessAppleEvent + 56
66 com.apple.AppKit 0x00007fff92c8e246 _DPSNextEvent + 1026
67 com.apple.AppKit 0x00007fff92c8da2b -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 122
68 com.apple.AppKit 0x00007fff92c81b2c -[NSApplication run] + 553
69 com.adobe.AfterEffectsLib.framework 0x000000010030d661 CApplication::Run() + 65
70 com.adobe.AfterEffectsLib.framework 0x000000010027ec96 MainMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, void**, int, int, int) + 918
71 com.adobe.AfterEffectsLib.framework 0x000000010027e8cb EggMain(bool, bool, bool, bool, bool, bool, unsigned short const*, bool, int) + 59
72 com.adobe.AfterEffects 0x00000001000038ae main + 1838
73 com.adobe.AfterEffects 0x0000000100003174 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff94f96662 kevent64 + 10
1 libdispatch.dylib 0x00007fff97da843d _dispatch_mgr_invoke + 239
2 libdispatch.dylib 0x00007fff97da8152 _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff94f95e6a __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff94f9ff08 _pthread_wqthread + 330
2 libsystem_pthread.dylib 0x00007fff94fa2fb9 start_wqthread + 13
Thread 3:: Dispatch queue: com.apple.root.low-priority
0 com.apple.CoreServices.CarbonCore 0x00007fff9160f988 DYLD-STUB$$strcmp + 0
1 com.apple.CoreServices.CarbonCore 0x00007fff9153e58a FSRefMakePathInternal(FSRef const*, unsigned char*, unsigned int) + 183
2 com.apple.CoreFoundation 0x00007fff9685357e CFURLCreateFromFSRef + 318
3 com.adobe.dvacore.framework 0x000000010339e689 dvacore::filesupport::FileHelper::Spec(FSRef const&) + 25
4 com.adobe.dvacore.framework 0x000000010339b359 dvacore::filesupport::FileIteratorHelper::GetFileHelper() const + 105
5 com.adobe.dvacore.framework 0x00000001033ac88a dvacore::filesupport::Dir::FileIterator::operator*() + 26
6 com.adobe.dvacore.framework 0x00000001033afc92 dvacore::filesupport::RecursiveFileIterator::operator*() + 18
7 MC.dylib 0x0000000101b186d1 MC_SortDir::ScanDiskCacheDir() + 657
8 com.adobe.dvacore.framework 0x00000001033d26e2 dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost::function const&) + 34
9 com.adobe.dvacore.framework 0x00000001033d15d8 dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr const&) + 184
10 com.adobe.dvacore.framework 0x00000001033e7dff dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT > const&) + 31
11 com.adobe.dvacore.framework 0x00000001033e7aff dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
12 libdispatch.dylib 0x00007fff97da62ad _dispatch_client_callout + 8
13 libdispatch.dylib 0x00007fff97da809e _dispatch_root_queue_drain + 326
14 libdispatch.dylib 0x00007fff97da9193 _dispatch_worker_thread2 + 40
15 libsystem_pthread.dylib 0x00007fff94f9fef8 _pthread_wqthread + 314
16 libsystem_pthread.dylib 0x00007fff94fa2fb9 start_wqthread + 13
Thread 4:
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
0 libsystem_kernel.dylib 0x00007fff94f95716 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x00007fff94fa0c3b _pthread_cond_wait + 727
2 com.apple.CoreServices.CarbonCore 0x00007fff915d6800 TSWaitOnCondition + 108
3 com.apple.CoreServices.CarbonCore 0x00007fff915d69ff TSWaitOnConditionTimedRelative + 172
4 com.apple.CoreServices.CarbonCore 0x00007fff915a7145 MPWaitOnQueue + 192
5 com.adobe.dvacore.framework 0x00000001033e623c dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr > >&, int) + 140
6 com.adobe.dvacore.framework 0x00000001033e4220 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 144
7 com.adobe.dvacore.framework 0x00000001033d63bc boost::function0::operator()() const + 28
8 com.adobe.dvacore.framework 0x00000001033e11a3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 115
9 com.adobe.boost_threads.framework 0x00000001081b88ae thread_proxy + 158
10 libsystem_pthread.dylib 0x00007fff94f9e899 _pthread_body + 138
11 libsystem_pthread.dylib 0x00007fff94f9e72a _pthread_start + 137
12 libsystem_pthread.dylib 0x00007fff94fa2fc9 thread_start + 13
Thread 14:
0 libsystem_kernel.dylib 0x00007fff94f9664a kevent + 10
1 com.adobe.dvatransport.framework 0x0000000107f3211c boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue&) + 236
2 com.adobe.dvatransport.framework 0x0000000107f31dc7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 375
3 com.adobe.dvatransport.framework 0x0000000107f31938 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 568
4 com.adobe.dvatransport.framework 0x0000000107f215b7 SkyConnectionEnv::MainLoop() + 167
5 com.adobe.dvatransport.framework 0x0000000107f21069 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 com.adobe.boost_threads.framework 0x00000001081b88ae thread_proxy + 158
7 libsystem_pthread.dylib 0x00007fff94f9e899 _pthread_body + 138
8 libsystem_pthread.dylib 0x00007fff94f9e72a _pthread_start + 137
9 libsystem_pthread.dylib 0x00007fff94fa2fc9 thread_start + 13
Thread 15:
2 com.adobe.dvatransport.framework 0x0000000107f31cdb boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 139
4 com.adobe.dvatransport.framework 0x0000000107f316ea boost::asio::detail::posix_thread::func::run() + 42
5 com.adobe.dvatransport.framework 0x0000000107f327d3 boost_asio_detail_posix_thread_function + 19
6 libsystem_pthread.dylib 0x00007fff94f9e899 _pthread_body + 138
7 libsystem_pthread.dylib 0x00007fff94f9e72a _pthread_start + 137
8 libsystem_pthread.dylib 0x00007fff94fa2fc9 thread_start + 13
Thread 16:: com.apple.audio.IOThread.client
0 libsystem_kernel.dylib 0x00007fff94f91a1a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff94f90d18 mach_msg + 64
2 com.apple.audio.CoreAudio 0x00007fff95b35918 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
3 com.apple.audio.CoreAudio 0x00007fff95b358a6 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
4 com.apple.audio.CoreAudio 0x00007fff95b3402e HALC_ProxyIOContext::IOWorkLoop() + 950
5 com.apple.audio.CoreAudio 0x00007fff95b33bcd HALC_ProxyIOContext::IOThreadEntry(void*) + 97
6 com.apple.audio.CoreAudio 0x00007fff95b33a8d HALB_IOThread::Entry(void*) + 75
Thread 17:
2 com.adobe.AfterEffects.MThread 0x0000000128abb76b boost::exception_detail::copy_boost_exception(boost::exception*, boost::exception const*) + 14395
3 com.adobe.AfterEffects.MThread 0x0000000128ab8e07 boost::exception_detail::copy_boost_exception(boost::exception*, boost::exception const*) + 3799
4 com.adobe.AfterEffects.MThread 0x0000000128abf371 std::vector, std::allocator > >::_M_insert_aux(__gnu_cxx::__normal_iterator*, std::vector, std::allocator > > >, boost::shared_ptr const&) + 4801
5 com.adobe.dvacore.framework 0x00000001033d63bc boost::function0::operator()() const + 28
6 com.adobe.dvacore.framework 0x00000001033e11a3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 115
7 com.adobe.boost_threads.framework 0x00000001081b88ae thread_proxy + 158
8 libsystem_pthread.dylib 0x00007fff94f9e899 _pthread_body + 138
9 libsystem_pthread.dylib 0x00007fff94f9e72a _pthread_start + 137
10 libsystem_pthread.dylib 0x00007fff94fa2fc9 thread_start + 13
Thread 18:
Thread 19:
Thread 20:
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
Thread 29:
2 com.adobe.AfterEffects.OpenEXR 0x000000012be4178c IlmThread::Semaphore::wait() + 70
3 com.adobe.AfterEffects.OpenEXR 0x000000012be40691 IlmThread::(anonymous namespace)::WorkerThread::run() + 65
4 libsystem_pthread.dylib 0x00007fff94f9e899 _pthread_body + 138
5 libsystem_pthread.dylib 0x00007fff94f9e72a _pthread_start + 137
6 libsystem_pthread.dylib 0x00007fff94fa2fc9 thread_start + 13
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
Thread 37:
Thread 38:
Thread 39:
Thread 40:
Thread 41:
0 libsystem_kernel.dylib 0x00007fff94f95a3a __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff8da6ddc0 nanosleep + 200
2 com.adobe.AfterEffects.Scripting 0x000000012e094898 png_write_filtered_row + 177512
3 com.adobe.AfterEffects.Scripting 0x000000012e07bd3e png_write_filtered_row + 76302
4 com.adobe.AfterEffects.Scripting 0x000000012e094455 png_write_filtered_row + 176421
5 libsystem_pthread.dylib 0x00007fff94f9e899 _pthread_body + 138
6 libsystem_pthread.dylib 0x00007fff94f9e72a _pthread_start + 137
7 libsystem_pthread.dylib 0x00007fff94fa2fc9 thread_start + 13
Thread 42:
2 libsystem_c.dylib 0x00007fff8da6dcb2 usleep + 54
3 Cineware_AE_SceneLayer 0x000000012fc7824a _melange_::IpKillThread::Main() + 58
4 Cineware_AE_SceneLayer 0x000000012fc79697 _melange_::BaseThread::Action() + 87
5 Cineware_AE_SceneLayer 0x000000012fc79579 _melange_::BeginThread(void*) + 9
Thread 43:
Thread 44:
2 RED_Handler 0x000000013b2966c0 R3DSDK::kdu_thread_entity::process_jobs(R3DSDK::kdu_thread_queue*, bool, bool) + 2512
3 RED_Handler 0x000000013b297af7 R3DSDK::worker_startproc(void*) + 23
Thread 45:
Thread 46:
Thread 47:
Thread 48:
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00000001146741c8 rbx: 0x0000000000000001 rcx: 0x0000000000000001 rdx: 0x000000011588be10
rdi: 0x00000001146741a0 rsi: 0x00007fff5fbf1598 rbp: 0x00007fff5fbf1670 rsp: 0x00007fff5fbf1640
r8: 0x0000000000000001 r9: 0x0000000000000000 r10: 0xa8037b6e0b522300 r11: 0xffff9e0115f0dc26
r12: 0x000000011588be10 r13: 0x000000000000073d r14: 0x0000000000000000 r15: 0x00000001146741a0
rip: 0x000000010127e703 rfl: 0x0000000000010202 cr2: 0x0000000000000845
Logical CPU: 4
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x100000000 - 0x100003ff7 +com.adobe.AfterEffects (12.2 - 12.2) <7D3E7F48-75F3-3FA4-A94D-2A25328BCACB> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/MacOS/After Effects
0x100009000 - 0x100017fff +com.adobe.boost_filesystem.framework (12.2.1 - 12.2.1.5) <19B6FB2D-8192-3365-9FF4-7C45DFB04A4B> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
0x10002b000 - 0x100037fff +com.adobe.boost_signals.framework (12.2.1 - 12.2.1.5) <981CAACC-2EF8-344C-A595-D0EAD53769DD> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0x100052000 - 0x100054fff +com.adobe.boost_system.framework (12.2.1 - 12.2.1.5) <6FBCAF22-A061-36F9-8ECB-6612C6BBAE7D> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x10005d000 - 0x100063ff7 +com.adobe.boost_date_time.framework (12.2.1 - 12.2.1.5) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x10007a000 - 0x10007cfff +ALOG.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/ALOG.dylib
0x100082000 - 0x100c21fff +com.adobe.AfterEffectsLib.framework (AfterFXLib 1.0 - 1.0) <3409043E-FC3D-3078-BDB5-0D7AAE318CCB> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
0x10107f000 - 0x10107ffff +AEFX.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/AEFX.dylib
0x101084000 - 0x1015c2fff +BEE.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/BEE.dylib
0x10185d000 - 0x10186dff7 +BEZ.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/BEZ.dylib
0x101876000 - 0x101880ff7 +BM.dylib (1) <4575C2D9-5BD4-319A-AD54-B1242E4A5314> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/BM.dylib
0x10188c000 - 0x1018fdfff +COR.dylib (1) <363501DE-C567-300A-87B6-8BF66E31EF9A> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/COR.dylib
0x101930000 - 0x10195afff +FILE.dylib (1) <430F6B09-0CD0-38F1-B785-9C7E32AF7366> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/FILE.dylib
0x101975000 - 0x1019ceff7 +FLO.dylib (1) <5AA5472A-7452-379B-9776-FD2771AA2E41> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/FLO.dylib
0x1019e2000 - 0x101a68fff +FLT.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/FLT.dylib
0x101ad8000 - 0x101adfff7 +LIST.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/LIST.dylib
0x101ae6000 - 0x101b01ff7 +M.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/M.dylib
0x101b0e000 - 0x101b38fff +MC.dylib (1) <5A8561B6-CBD0-34ED-9982-A2474EF41AAB> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/MC.dylib
0x101b55000 - 0x101bc6ff7 +MSK.dylib (1) <102E439A-CD58-3ADC-8DDE-913873400E92> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/MSK.dylib
0x101bee000 - 0x101c34ff7 +OM.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/OM.dylib
0x101c4f000 - 0x101c73fff +P.dylib (1) <6B6BC05F-12AE-3C36-907D-CAB5213164BF> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/P.dylib
0x101c83000 - 0x101f4cff7 +PF.dylib (1) <074FA097-C4BF-3DA2-926F-2A22F7F54489> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/PF.dylib
0x10201e000 - 0x102292fff +PIN.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/PIN.dylib
0x102374000 - 0x10238fff7 +PLUG.dylib (1) <2C2A8980-E701-3EB8-913E-CF51DBBC570F> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/PLUG.dylib
0x1023a2000 - 0x1023aaff7 +PR.dylib (1) <6F7358C0-16D4-361C-9D29-8C5DF06F8F1B> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/PR.dylib
0x1023b3000 - 0x1023c3fff +PREF.dylib (1) <8C4D2EE6-1C6B-354F-9AB6-F0BE17A2974B> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/PREF.dylib
0x1023d0000 - 0x1023edff7 +RG.dylib (1) <52BA395B-AEC5-3635-AAA1-32E669151F27> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/RG.dylib
0x102401000 - 0x102402fff +RI.dylib (1) <80FA3141-8A09-31BF-93F9-5D965778AB8D> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/RI.dylib
0x102407000 - 0x102408fff +RND.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/RND.dylib
0x102411000 - 0x102478ff7 +SLU.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/SLU.dylib
0x1024b6000 - 0x1024d8fff +SND.dylib (1) <76B18FFE-EAD1-37E9-BFB4-F67A9BDEC609> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/SND.dylib
0x1024ea000 - 0x1024edff7 +STR.dylib (1) <1C06A483-C383-39AC-B2BC-FEBC1A466EB8> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/STR.dylib
0x1024f4000 - 0x1024f8ff7 +T.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/T.dylib
0x1024ff000 - 0x10253dff7 +TDB.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/TDB.dylib
0x10255a000 - 0x102bfcfff +TXT.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/TXT.dylib
0x102f7f000 - 0x102fe9fff +U.dylib (1) <7E5D4CA9-C6E8-3D39-A367-C471E9840A5F> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/U.dylib
0x103020000 - 0x103024ff7 +VAL.dylib (1) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/VAL.dylib
0x10302b000 - 0x1030f5fff +com.adobe.exo.framework (12.2.1 - 12.2.1.5) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/exo.framework/Versions/A/exo
0x10324f000 - 0x103279ff7 +PREM.dylib (1) <977521C0-B85E-3791-A27E-4E221E6A79E4> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/PREM.dylib
0x103298000 - 0x1032f7ff7 +FRP.dylib (1) <1F28C6D3-DE95-397E-B32D-6A7D5DBF8068> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/FRP.dylib
0x10331d000 - 0x103580ff7 +com.adobe.dvacore.framework (12.2.1 - 12.2.1.5) <655E833D-DF55-373C-B823-153ECBBA1130> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
0x1037a7000 - 0x103c56ff7 +com.adobe.dvaui.framework (12.2.1 - 12.2.1.5) <87885E70-C9A4-3E1D-A4DA-E8174D7DB969> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
0x104252000 - 0x10430eff7 +com.adobe.dvaworkspace.framework (12.2.1 - 12.2.1.5) <7D3BC433-2B22-3776-BDE1-B60FB51A4C40> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
0x10441d000 - 0x104440fff +com.adobe.dvaunittesting.framework (12.2.1 - 12.2.1.5) /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
0x104481000 - 0x1044c6fff +com.adobe.dynamiclinkui.framework (12.2.1 - 12.2.1.5) <3204E43A-3CA1-3737-A210-F877D4022C4A> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/dynamiclinkui.framework/Versions/A/dynamiclinkui
0x104540000 - 0x104751fff +com.adobe.dynamiclink.framework (12.2.1 - 12.2.1.5) <3C3274C4-288F-3B58-9447-C1D0AED860DB> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
0x104998000 - 0x1049e4fff +com.adobe.ASLFoundation.framework (12.2.1 - 12.2.1.5) <0A08B0B9-08DA-3861-9810-F389F3C0BA1B> /Applications/Adobe After Effects CC/Adobe After Effects CC.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
Kevin Camp
Re: AE crashes when opening project
on May 9, 2014 at 5:38:55 pm
here's a few things i typically try in similar scenarios.
first, try opening the project from after effects (file>open).
second, try opening the project with the caps lock on (this prevents rendering the preview, which can help if it is an effect that is causing the crash). if that works, then you'll need to go through the open comp and try to find the offending effect, which can be tedious if you have many layers and effects.
third, try importing the project rather than opening it.
fourth, reset the prefs by either moving them to a folder on your desktop and or by starting ae while holding ctrl-alt-shift.
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
rikard lassenius
on May 12, 2014 at 7:25:55 am
thanks, but no luck with the standard tricks.
i manage to open up a auto-save version of the project files (when it can't find the illustrator files). tried to make different versions of the drawings (smaller, older ai-format, ...) but nothing seems to help. when replacing the ai-files, ae crashes, getting a message that refers to that last log message concerning "ae.blitpipe"
Peter Todd
on Mar 25, 2015 at 4:53:34 pm
I know this is old but google found it.
I had a similar issue with AE and Premiere rather than illustrator. I had some shared content.
To resolve it I found that if Premiere was open the project would load fine in After Effects.
Strange but might be the same with illustrator and perhaps other, not tested.
