Recessing Brick Animation
Ari Grunzeweig
on May 8, 2014 at 4:42:27 pm
I'm working on an animation where bricks move backwards randomly to a specific point in the wall. Then a second layer of bricks will move back. See attached animation for first layer moving.
Brick Test V1
The problem is that do get nice shadows I have to set the shadow map resolution of my comp to 4000. When doing this, I get RAM errors when rendering out my animation at 1080p.
The bricks are all made in a precomp where 5 jpeg sides are arranged to form a brick. No back wall, as we never see it. They all those precomps are put in a master comp with collapse transformations and then arranged to make the wall.
So my questions are as follows?
1. Is there an easier or more automated way of doing this? Perhaps with a script or something similar?
2. If not, does anyone have any tips to make this less heavy on the rendering/RAM/processing? Basically, make the setup more efficient.
I am using an i7 iMac with 16gb of RAM with AE CC on Mavericks.
Thanks so much!
Ari
Dave LaRonde
Re: Recessing Brick Animation
on May 8, 2014 at 5:10:37 pm
This is more easily done in C4D Lite, which you also have.
Dave LaRonde
Promotion Producer
Ari Grunzeweig
on May 8, 2014 at 5:13:59 pm
I had a feeling that would be the case.. but I only have minimal experience with C4D. Any clue where I start on something like this?
Ari
Dave LaRonde
on May 8, 2014 at 5:44:17 pm
Someone who actually runs AE CC ought to help you with that.
I refuse to get sucked into the rental vortex.
Dave LaRonde
Promotion Producer
Walter Soyka
on May 9, 2014 at 3:40:34 am
[Ari Grunzeweig] "I had a feeling that would be the case.. but I only have minimal experience with C4D. Any clue where I start on something like this?"
The tools that would make this animation really straighforward -- the cloner and effectors in the C4D Mograph module -- are not included in C4D LITE.
That said, you could still build and animate this pretty quickly by hand, but you should expect a bit of a learning curve. If you're looking for training, I think the best place to start is Cineversity.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Roland R. Kahlenberg
on May 9, 2014 at 5:22:37 am
You will also get nice shadows with the Ray-traced Renderer. The issue it may introduce is increased render times.
HTH
RoRK
Gaudy Teaser for an upcoming AE Type Gizmo.
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
