Change dot with comma
Michael Davydov
on May 5, 2014 at 5:59:04 pm
I have a simple code, showing an animated Slider number in a text field. It is a number with a floating point, like 29.3. And now I was asked to replace DOT with COMMA, to make it look like 29,3, and I don't know how to do it.
What is the right way to replace dot with comma in that matter?
Thanks.
Declan Smith
Re: Change dot with comma
on May 5, 2014 at 7:20:54 pm
Use the replace method of the string representation of the number.
For example:
numStr = "" + 12.35
numStr.replace(".", ",")
So if your text field is something like:
thisComp.layer("Control").effect("Slider Control")("Slider")
Change it to read
numstr="" + thisComp.layer("Control").effect("Slider Control")("Slider").value;
numstr.replace(".",",");
Declan Smith
http://www.madpanic.tv
After Effects CS6/ FCS3 / Canon XLH1 / Canon 7D / Reason / Cubase
"it's either binary or it's not"
