Export to XFL removed form AE cc
Rob Lucas
on May 2, 2014 at 11:22:52 am
For some reason Adobe has removed the export to XFL option in CC, does anyone know a work around for this?
I have tried exporting a .swf, which plays back correctly, however won't import into flash. This may be user error as I don't know flash all that well (hence trying to create animation in AE!)
Is the export to xfl now redundant or is it just bad luck for me?
Roland R. Kahlenberg
Re: Export to XFL removed form AE cc
on May 2, 2014 at 2:35:47 pm
Don't know about XFL but you can export to FLV and F4V via AME. Most of these non-broadcast formats seem to be moving out from AE output/render. AME will continue the support.
HTH
RoRK
Gaudy Teaser Promo for an upcoming AE Type Gizmo.
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
Todd Kopriva
on May 3, 2014 at 3:06:41 am
See this for a detailed explanation of why we removed this feature.
After Effects team blog
Rob Lucas
on May 12, 2014 at 8:54:32 am
Thanks Todd,
Sounds like a good enough reason to me, I was only hoping to use AE as I don't know Flash all that well, but I guess i'll have to stop being so lazy and learn something new!
