After Effects, Shatter Effect
Ryan Meunier
on Apr 29, 2014 at 8:11:51 pm
Cannot figure out if I'm over complicating things or if it's just a brain fart. I've created a logo and extruded it in After Effects using the Create Vector Shapes from object feature. Blah blah blah it appears as if it's 3-D now. I'd like to shatter this object using the shatter effect. However when I apply the shatter effect to the outlined object, it doesn't shatter. Any suggestions? I've shattered text and such, is this not available for extruded objects? Please help.
Joseph W. Bourke
Re: After Effects, Shatter Effect
on Apr 29, 2014 at 8:35:54 pm
I would suggest that you precomp your 3D logo. It's not likely that the Shatter effect works on 3D extrusions, since it is obviously creating its' own pseudo 3D in the shatter menu. Of course, by precomping, you're going to lose the ability to move the logo in actual 3D space as well, but it might work for your needs.
Joe Bourke
Owner/Creative Director
Bourke Media
Ryan Meunier
on Apr 29, 2014 at 8:37:09 pm
Yes this is what I had to settle with, much appreciated Joseph. Thank you.
Roland R. Kahlenberg
on Apr 30, 2014 at 2:11:35 am
You've very likely applied Shatter to the extruded layer without first nesting the extruded layer. It's a Ray-traced rule that extruded layers will disregard effects applied to them.
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
© 2018 All Rights Reserved
