smooth audio keyframes
Vesko Anev
on Apr 27, 2014 at 8:16:15 am
Hello im doing an audio reaction based on a song. The problem i have is that i need my animation to be smooth but also limited . Im applying the effect on a twist in trapcode form and i want this twist to be limited to 4 ,but also i want the changes to be done smoothly. My Audio amplitude is giving values from 0 to 50 more or less and with linear(value,0,45,2,5) i have some result but i want to smooth it . When i use smooth after linear its not working. I tried using linear to the amplitude layer and smooth to the twist effect and the oposite but its still not working
George Goodman
Re: smooth audio keyframes
on Apr 28, 2014 at 1:22:17 pm
Did you try using the smoother? Window>Smoother. Highlight all the keyframes and apply. It will knock down the amount of keyframes.
"|_ (°_0) _|"
Sincerely,
George
