When previewing, why does it always re-process whole work area even when I make a small change?
Ian Dillon
on Apr 24, 2014 at 3:08:24 am
I just bought a new MacBook Pro and AE CC. I have been using After Effects for decades, however. I don't remember it ever doing this. Do I have a setting wrong?
When I preview my work area by pressing zero on the numeric pad, it calculates and previews fine. However, when I make a slight change, even to the audio track, it reprocesses the whole thing again, even if the part it is reprocessing was not even near the keyframes I was manipulating. Shouldn't that part still be untouched in the buffer? I have tried with draft mode, and fast preview mode.
I'm sure there must be some setting I have wrong???
Thanks in advance,
Ian.
Mac Pro 2x2.66 GHz Dual-Core Intel Xeon
8 GB Ram
Blackmagic Decklink Studio 2 Card
Playroom Creative
We are an Orange County Video Production and Marketing company.
http://www.PlayroomCreative.com
George Goodman
Re: When previewing, why does it always re-process whole work area even when I make a small change?
on Apr 24, 2014 at 2:07:14 pm
Try purging your memory. Also, check your disk cache allotment.
If the timing is even slightly changed in the video, it has to recalculate. If you put a keyframe at the end, but remove one from the beginning, it has to recalculate also since there is no keyframe where there once was.
"|_ (°_0) _|"
Sincerely,
George
Dave LaRonde
on Apr 24, 2014 at 5:38:53 pm
If you tweak a layer that's the same duration as the composition, that'll happen. If you tweak a 2-second clip in a 30-second comp, AE only has to think about that 2-second bit.
Dave LaRonde
Promotion Producer
