Difficulty with preview in After effects 6 and CC
Ai Hideki
on Apr 23, 2014 at 6:55:17 pm
I am working on a project in After effects 6, and a recent issue has occurred. As I scrub the composition is accurate in scale (image on left), but if I attempt a ram preview, it zooms in and compresses the subject matter in an odd way (image on right). I am unable to view the compositions properly unless i pre render into an .mov file and replace the comp. Both 2d and 3d layers are affected. I have opened the project in both ae6 and CC, and have installed all available updates, but nothing seems to fix the issue. Any help on this matter would be appreciated.
OS x
16 gig ram (13 allocated to AE)
2.7 ghz intel core processor
Roland R. Kahlenberg
Re: Difficulty with preview in After effects 6 and CC
on Apr 24, 2014 at 1:56:22 am
Your image is poorly compressed and this hides a lot of the information in the UI. If you want to post something, please ensure that it is of sufficiently good quality.
As for your issue, it's very likely a graphics card issue. What GPU are you using and have you ensured that you have the latest drivers installed for this GPU?
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
Ai Hideki
on May 5, 2014 at 1:45:31 pm
Ah apologies. Thank you for your feedback. It was in fact an update issue. Thank you!
