Render Times
Timothy Shay
Render Times
on Apr 23, 2014 at 12:13:39 am
Running the latest version of AE; CS6 Suite
My specs are:
Mac OS 10.9.2
2.6GHZ Intel Core i7
16GB RAM
1TB Hard Drive (about 20GB left)
After Effects is taking an incredibly long time to render. I'm wondering how to speed it up. Would my low HD space have anything to do with it?
Roland R. Kahlenberg
Re: Render Times
on Apr 23, 2014 at 1:07:43 am
It's a good idea to restart AE prior to initiating a render. Quite often, I find my render times drop significantly when doing this.
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
Brian Charles
Re: Render Times
on Apr 23, 2014 at 1:53:25 am
In addition to Roland's excellent tip, here are some links with information about improving After Effects performance in general.
https://blogs.adobe.com/aftereffects/2010/03/performance-tip-dont-oversched...
http://helpx.adobe.com/after-effects/using/improve-performance.html
There are many potential bottlenecks and issues that can cause long slow renders. Obvious ones like large files to be read and written, hundreds of layers and effects, not enough RAM, slow media drives, etc and some not so obvious bottlenecks which are discussed in the links above.
Timothy Shay
Re: Render Times
on Apr 24, 2014 at 3:12:34 pm
Thank You both. The best solution I've found is to use Dynamic Link, and work with Premiere for all my rendering and exporting needs.
