Creating a Set First Vertex Keyboard shortcut for a Mask
nikhil tanenquin
on Apr 22, 2014 at 4:59:33 am
I have been using AE for about 10 years now so know my way around the software. Although not very strong on technical side of it. I was trying to create a keyboard shortcut for this pull down menu
Layer > Mask and Path Shape > Set First Vertex
I went through a few tutorials of how to modify the Keyboard Shortcuts text documents, no luck. Also installed the KeyEd Up.jsx and still no luck.
I thought surely there would be someone on this forum who would know. Thanks in advance.
Nikhil
Roland R. Kahlenberg
Re: Creating a Set First Vertex Keyboard shortcut for a Mask
on Apr 22, 2014 at 6:02:45 am
There is no built-in shortcut key for selecting/applying a First Vertex. Can KeyEd Up.jsx link a user-created shortcut to a menu item?
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
nikhil tanenquin
on Apr 22, 2014 at 8:59:29 pm
I figured it out, I went in to the txt file and made changes to the script.
Under ["CSwitchboard"]
"MaskSetFirstVertex" = "(Ctrl+Shift+Alt+M)"
Then save the txt file and restart AE, the last step is what I overlooked. So its all good now.
Nikhil
on Apr 24, 2014 at 12:54:24 am
Many thanks for reporting back. :-)
HTH
RoRK
