880m with 4800mq VS 870m with i7-4940MX
shane Scott
on Apr 21, 2014 at 11:26:19 am
Hi i'm going to get an MSI dominator for AE with 32gigs RAM and SSD. What do you guys think will be better, the 880m with 4800mq OR 870m with i7-4940MX which will cost $300 more? do you think the extra processing power is worth the $300 and having to get a lower GPU? (I can't afford an 880m with 4940MX)
do you guys think the boost in performance from the 4800mq to i7-4940MX will be worth the extra $300? will the difference be significant or hardly noticable? basically upgrading 4800MQ to i7-4910MQ is $245 then i7-4910MQ to i7-4940MX is another $550 and the difference seems to be .2GHz, what do you think i should go with?
Todd Kopriva
Re: 880m with 4800mq VS 870m with i7-4940MX
on Apr 21, 2014 at 3:07:31 pm
You got answers here:
http://forums.adobe.com/message/6314342
After Effects team blog
