After Effects CS6 Shows Nothing but Blackness!!
Josh Pulido
on Apr 18, 2014 at 7:29:09 pm
My Adobe After Effects Project was going smooth, until i decided to render it out, then got a long error, so i was gonna go back and render it out in chunks, but then everything in my composition window went black, i scroll through the composition, and nothing comes out.. Please help This project is due soon thanks!
-Josh Pulido
John Cuevas
Re: After Effects CS6 Shows Nothing but Blackness!!
on Apr 18, 2014 at 7:36:39 pm
Start by purging the cache (Edit > Purge).
If that does't help, post a screen grab of your timeline and comp window.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
chris brett
on Apr 19, 2014 at 11:31:53 am
Hi Josh
---------------- this has happened to me also --- the black is no problem the comp is still there ---- just clear all the cache areas and reboot the machine -- should load normally and off you go...
--- seems to me that memory areas are not automatically cleared and fill up causing problems .....
I clear as below - its probably a bit 'belt-and-braces' but seems to work for me......
edit / purge / / all memory plus image cache memory
also
edit / preferences / media and disk cach / empty disk cache plus clean database and cache
Then exit AE and reboot the machine.
Editing in sections has worked for me when I've had real problems in the past --- just render as sequential files till it crashes / delete last rendered frame in case corrupt / then re-render from that frame number straight into same folder till it crashes again or finishes etc --- its a pain but no real problem ...
------------------------------------- chris ---
Josh Pulido
on Apr 19, 2014 at 1:28:21 pm
Alright it worked thank you:)
