Render ends when I switch to another application
Matthieu Foulet
on Apr 16, 2014 at 1:41:36 pm
Hi there,
I have an unexpected issue when I launch a render in AE.
The render stops (no crash, I here the little ending melody) whenever I launch it and switch to any other application (to keep on working on something or to go procrastinating on reddit) !
I am running the latest build of After Effects CC, with multiprocessing on, using a PNG sequence render setting, on an Full HD composition, with no 3rd party plugin used.
Any thoughts ?
MacPro 8Core 2.8Ghz (Early2008) //
16GB OWC RAM //
ATI Radeon HD5770 1Go //
OS X.9.2
Dave LaRonde
Re: Render ends when I switch to another application
on Apr 16, 2014 at 10:31:23 pm
Use a different computer to do other things while AE renders. You get used to it.
Dave LaRonde
Promotion Producer
Matthieu Foulet
on Apr 16, 2014 at 11:26:45 pm
Can you mail me a few thousand bucks so that I can buy a second computer ?
THAT would be helpful.
16GB OWC RAM //
OS X.9.2
Tyler Hurst
on Apr 16, 2014 at 11:44:49 pm
Mac OSX Mavericks has a feature called App Nap where it stops powering any application that isn't immediately in front of it. Here's an article about it
http://www.tekrevue.com/tip/disable-app-nap-os-x-mavericks/
All you need to do is click get info on the application and "prevent app nap"
Matthieu Foulet
on Apr 17, 2014 at 8:00:46 am
I didn't know about app nap, I will look into that.
16GB OWC RAM //
OS X.9.2
Dave LaRonde
on Apr 17, 2014 at 3:02:26 pm
Got a smart phone?
Dave LaRonde
Promotion Producer
Matthieu Foulet
on Apr 17, 2014 at 3:03:42 pm
Sure, but I can't find a good editing app for it ;)
16GB OWC RAM //
OS X.9.2
Tero Ahlfors
on Apr 17, 2014 at 6:16:56 am
[Matthieu Foulet] "with multiprocessing on"
You're probably running out of RAM when you're using other applications when rendering. That will stop the render.
Matthieu Foulet
on Apr 17, 2014 at 8:04:09 am
That's what I thought because the issue does not occur with multiprocessing turned off.
I will tweak my settings to see if I can get rid of the problem.
16GB OWC RAM //
OS X.9.2
