Cache Work area in Background fails
Anthony Dupsta
on Apr 11, 2014 at 11:56:40 pm
I have never been able to get this to work.
I have emptied the cache folders. In theory this sounds promising. Just always fails on me? Keep in mind I have only tried this about 10 times, with this set up.
Any suggestions to help me trouble shoot this and get this working?
Thanks guys
Dave LaRonde
Re: Cache Work area in Background fails
on Apr 12, 2014 at 1:06:12 am
Sorry, but we wouldn't be very useful without a a whole lot more information:
https://forums.adobe.com/message/4200845#4200845
Dave LaRonde
Promotion Producer
Anthony Dupsta
on Apr 12, 2014 at 1:21:08 am
I am working on AE CC OS 10.9.2
No third party hardware. No external drives.
Exr's are in the precomp, just keeps failing on me. I am working in Linear space. No quicktimes.
Full text of the error message is represented in the image I uploaded,
"Unexpected error in CacheFramesToDisk"
I have used this option before once or twice, possibly when I was not working in Linear space? Not sure if those variables correlate?
I do not have "Multiple Frames Simultaneously" checked on, it is off.
Classic 3d is on not ray traced.
I have re-booted a few times, this has been occurring over the last few days.
Anthony Dupsta
on Apr 12, 2014 at 1:46:14 am
No rhyme or reason that I can figure out. I imported an EXR seq from a diff job in a new project and set it up. That started to BG cache with my nice blue line. All good.
I can get it to work sometimes and than magically sometimes it will error out. All this with out any variables?
I switched back into the comp I could not get to work and clicked to cache the back ground and it began to work? So I than cleared all my memory and data base. That same comp would not BG cache after I purged memory and disk cache. NO go. I resarted AE, it began to work.
It seems that it is finicky? I can not dial in why it does and does not work? It is hit or miss. I just purged the system and it now is caching. I am just putting this out there encase others have this strange hit or miss thing happening.
Michael Szalapski
on Apr 14, 2014 at 1:29:23 pm
Your version number of AE is 12.2.1, right?
What are your computer's specs? Processor, RAM, etc. One thing specifically is what kind of hard drive(s) do you have?
- The Great Szalam
Anthony Dupsta
on Apr 14, 2014 at 6:07:58 pm
I will keep an eye on this, got to figure out this strange hit or miss BG caching issue. This week I will take note and try it on all the diff comps and see if I can find a pattern. One variable; I will hook up a thunderbolt EXT drive and designate that as the cache drive. Just as a test. However here are the specs for my HD and system while I have been experiencing this BG caching issue. Right now, I will hook up and try an EXT drive this week as a test.
Here are the Specs, specifically the HD
Seagate ST31000528AS 1TB
Journaled HFS+
AE 12.2.1.5
Mid 2011 iMac
3.4 GHz Intel Core i7
32GB DD3
AMD 6970M
OS 10.9.2
Anthony Dupsta
on Apr 16, 2014 at 7:12:40 pm
Just encase anyone runs into this issue or his thread.
This has been working with some project files and others it is hit or miss. I am working in a Linear work space with EXRs. It seems that when if calls out the error and will not cache in the BG. Nothing will get it working, I have to restart AE, change project files, and when I get it to work on a diff project file, I can come back to the ones that don't work, and it will begin to cache. I have tried switching disks. But the issue continues. I am trying to weed out the variables. So far the constant variable is all my test are within a Linear working color space. I am going to swap out some of the third party plug-ins and see if those are factors?
