Render settings
Spencer Tycksen
Render settings
on Apr 10, 2014 at 9:13:27 pm
I have a comp that is taking forever to render. The comp is 3d, has particles, motion blur, camera wiggle, and is 5 minutes long - thus the long render. I had it rendering for 2 and a half days and then the external drive that I was using got bumped and it disconnected, so I lost the render. I'm about to restart, but I'm wondering if there is anything I can do to make it render faster.
Does it make a difference whether I render to a local drive as opposed to an external? Here are my current memory settings:
Also, if I use Adobe Media Encoder to render rather than rendering right from After Effects, does that make any difference?
Any tips would be greatly appreciated. Thanks.
mathew fuller
Re: Render settings
on Apr 10, 2014 at 9:44:04 pm
Commenting on how to make your render faster is too complicated a thing without getting deep into your project. I will say this.
- Don't render to an external drive, just a bad idea for many reasons, one of which you experienced.
- I'd render an image sequence rather than a movie. That way if it crashes you can resume your render where it failed.
- Try this script for BG rendering
My Work:
© 2018 All Rights Reserved
