Change position in a Time Remapping Loop after each loop
Diego Mellado
on Apr 3, 2014 at 11:20:12 am
Dear all,
I am trying to move a fixed amount of pixels a layer after each cycle on a Time Remapping loop (loopOut("cycle"))
I am not sure if this is possible, but it seems that using type="offset" can do it. I can't find how.
Could somebody throw some light?
Best,
Diego
Darby Edelen
Re: Change position in a Time Remapping Loop after each loop
on Apr 4, 2014 at 12:53:19 am
Do you want the layer to jump a certain distance when a loop completes or move a distance over the life of the loop?
Darby Edelen
Diego Mellado
on Apr 4, 2014 at 6:27:42 am
Hello Darby, and thanks for your interest.
I would like it to move once each cycle has finished.
I were able to do it using hold keyframes in the position property and a loopOut("offset") expression but I would like the movement to be erratic, not always in the same direction. Is it even possible?
Best and thanks again,
Diego
Dave LaRonde
on Apr 4, 2014 at 3:45:07 pm
It sounds like you'd want the position changes to be random... but in my experience, the term, "random" isn't often desirable. It's more in the eyes of the person: "Yeah, that nice and random like I'd want it to look"..... when in fact there's a pattern to it.
In which case, I would forget the loop expression, use multiple layers, and just move each layer where you want it to be. This has two virtues: it's straightforward and fast, and easily changed.
Dave LaRonde
Promotion Producer
Diego Mellado
on Apr 7, 2014 at 11:36:23 am
Hi Dave,
First of all, thanks a lot for your suggestions.
I already considered that option. I have 150 layers looping, I just dind't want to move them manually, that's waht I was asking for a pseudo-random movement.
Best,
Diego
