i want jaggy line of "one pixel"
brice tokarz
on Apr 1, 2014 at 2:34:05 pm
Hello
I want to animate line of perfect one pixel. I tried to turn off the best quality switch in the timeline, mosaic effect, 3D stroke ....
As you can see in this image I only got the second one, I want the third one.
Brice
Joseph W. Bourke
Re: i want jaggy line of "one pixel"
on Apr 1, 2014 at 3:17:27 pm
It will help to know what resolution you're working at, and the size of that line within the resolution.
Joe Bourke
Owner/Creative Director
Bourke Media
http://www.bourkemedia.com
brice tokarz
on Apr 1, 2014 at 3:44:37 pm
Hi Joe
I'm working in a 1920/1080 comp.
here a image of what I want
You can see in this video at 2'47
ben g unguren
on Apr 1, 2014 at 4:08:36 pm
Interesting dilemma.
While not perfect, this got me pretty close: New Comp, New Layer -- I created a mask/path, then applied the Stroke effect. I set it the effect to Paint on Transparent, Hardness to 100%, Brush Size around 1.6 (this is the critical setting, which you'll want to adjust to taste). Then I created an Adjustment Layer with a Levels effect. Set the Level's filter Channel to "Alpha", then slide the Alpha Gamma to 0.00. This gave me a nice, nasty jagged line, with most parts (but not all) exactly one pixel wide (you'll have to precomp it if you want to put it on top of anything else). Adjust the Stroke Brush Size until you get the width you like best.
The only thing that comes to mind to get EXACTLY what you want it is to create the final pixelated line in photoshop, pixel for pixel. Then use your preferred method to reveal the line in AE (masking, painted mask, animated stroke, etc).
Keep in mind that often a single-pixel line isn't single pixel in the end, but aliased, with softened edges. Most people can't tell the difference; in fact, they will see an aliased line as single pixel more readily than a non-aliased one. Especially when it's a part of a motion graphics piece.
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.com
brice tokarz
on Apr 1, 2014 at 4:38:05 pm
Hi Ben
Thank you for your help.
It's pretty close of what I want. I got a line of 2 pixels instead of 1 pixel.
Maybe the only way to get this is programming (flash As3or processing).
But I want to find a way to do this in After effects :)
I will let you know if I find something.
Brice
