Text Flickering after effects.
Esteban Bustos
on Mar 31, 2014 at 6:35:22 pm
im trying to solve this thing out
1920 x 1080
29.97 fps
Font: Arial
motion blur off
https://www.dropbox.com/s/b1y6if8ppnqk8yr/muestra%20solucion.mov
render: Full resolution quicktime - Animation
text is in 3d as well as the grey layer in the back. Text ins´t moving, it´s just a camera parent to a null. How do i avoid the flickering or the bluriness.
After FX CC updated
thanks in advanced.
Dave LaRonde
Re: Text Flickering after effects.
on Mar 31, 2014 at 6:41:38 pm
Why do you need to use 3D? I didn't see a single thing in that clip that said to me, "You MUST use 3D!" Life is much simpler in 2D.
"Flickering" is a subjective term at best. For me candles flicker, not text.
If you're describing the horizontal motion that doesn't look smooth, you're experiencing judder, which is a function of motion and frame rate. To fix it, you either change the motion or change the frame rate.
Dave LaRonde
Promotion Producer
Esteban Bustos
on Mar 31, 2014 at 6:52:34 pm
i know it isn´t a must xD.
So in order to get rid of judder i must put more time on the animation from point A to point B? make it slower?
(sorry for my bad english)
Dave LaRonde
on Mar 31, 2014 at 7:55:18 pm
[Esteban Bustos] " ...i must put more time on the animation from point A to point B? make it slower?"
Making it faster may also help. It will be a matter of experimentation. If you aren't using Motion Blur yet in AE, you can try that, too: it can help.
Dave LaRonde
Promotion Producer
Esteban Bustos
on Mar 31, 2014 at 7:57:14 pm
thanks buddy!
