Alpha channel and black background
Bernhard Walzl
on Mar 28, 2014 at 6:36:01 pm
Hello!
I just came across something weird and I was wondering if one knows what is going on here:
I have a comp which is entirely transparent. I place a logo in a corner, which transparency is on 40%. I export it using the codec Animation, preserving the Alpha channel.
Then I do the same again but with a solid black layer in the background (the transparency of the logo is still on 40%).
Surprisingly, the results of the two logos will be different:
See this picture, to understand what I mean:
I understood that transparency will be interpreted black when there is nothing in the back, so I am quite surprised why the two results differ.
Thanks for sharing your ideas,
Bernhard
Dave LaRonde
Re: Alpha channel and black background
on Mar 28, 2014 at 10:32:02 pm
what is the codec for the NON-alpha-channel version, and how are you going about combining the two in your illustration?
Dave LaRonde
Promotion Producer
Bernhard Walzl
on Mar 28, 2014 at 11:06:08 pm
Both were encoded using the codec ANIMATION (plus alpha) with the same settings. The picture is done with photoshop to demonstrate the difference. But I can render it out by placing the solid black half behind the icon.
Walter Soyka
on Mar 30, 2014 at 12:24:11 am
Are you correctly interpreting the alpha when you re-import the test? You'd get wrong results if you rendered with pre-multiplied alpha but interepreted as straight alpha.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Bernhard Walzl
on Mar 30, 2014 at 12:38:30 am
I have exported and viewed the exact same way.
After rendering out the first version, I have created a black solid in the back, then for the export, I have duplicated the old render entry to get the exact same result.
The picture I have taken is a screenshot what quicktime displays.
Can someone reproduce this? I am happy to upload my after effects file...
Walter Soyka
on Mar 30, 2014 at 1:02:24 am
There is no image uploaded here.
If you collect your project and source footage, zip it up and upload it, I'll take a look at it tonight for you.
Walter Soyka
Bernhard Walzl
on Mar 31, 2014 at 6:57:20 pm
Thanks Walter!
Please find here the AEP file: 7315_iampuzzled.aep.zip
//edit: sorry I just realized my default font was not a standard one, feel free to change it, it will produce the same result.
It is white text with 40% opacity. Through the center is a solid black in the background while the upper and lower part stays transparent. Rendered as Animation, preserving the Alpha channel, and when viewing in Quicktime it will look like this:
My question: Why.
Dave LaRonde
on Mar 31, 2014 at 9:34:29 pm
My question: why are there two distinctly different shades of gray in your picure?
Sorry, but I'm unable to download the project. My fault, not yours.
Dave LaRonde
Promotion Producer
Bernhard Walzl
on Mar 31, 2014 at 9:36:03 pm
Because through the middle runs a solid black layer in the background. the upper and lower bit are kept transparent.
Walter Soyka
on Mar 31, 2014 at 10:53:38 pm
[Bernhard Walzl] "when viewing in Quicktime it will look like this:
My question: Why."
Any question about why things look the way they do in QuickTime Player is virtually unanswerable.
If you bring this into an alpha-aware application, it will display correctly.
Walter Soyka
Bernhard Walzl
on Apr 1, 2014 at 12:23:17 am
yes, VLC will play it correctly.
however, the problem started off that I have two videos: one is an intro and the other is a logo (which has video footage in the background). one has a black background, the other one is transparent whereas both use the animation codec.
when I put them in the timeline (premiere cs6) next to each other, export as h264, their grey tone will change.
So I am just trying to find out where the root of this problem sits, to solve this issue.
No need to propose me a workaround, i want to know why things are how they are.
Any help with this is highly appreciated.
Walter Soyka
on Apr 1, 2014 at 12:39:45 am
[Bernhard Walzl] "when I put them in the timeline (premiere cs6) next to each other, export as h264, their grey tone will change. So I am just trying to find out where the root of this problem sits, to solve this issue. No need to propose me a workaround, i want to know why things are how they are."
Ah, I see now. The Premiere part was important!
I think that the issue here is that Premiere CS6 composites in a linear space when accelerated by GPU, but in a gamma-encoded space without GPU acceleration.
If you turn off GPU acceleration in Premiere (Project > Project Settings > General, then set the Renderer to "Mercury Playback Engine Software Only") then you should not see this shift in gray tones.
Walter Soyka
Bernhard Walzl
on Apr 2, 2014 at 7:56:44 pm
Thats right! Thanks Walter!
Very interesting indeed. Is there any news out there why this is happening from a technical point of view?
