Combining masks for element 3D extrusion
Matt McGrath
on Mar 28, 2014 at 10:32:22 am
Hi All,
I'm working on a simplified world map image that is constructed of rounded rectangles that I created in photoshop, I'd like to select the image and extrude it in Element 3D.
I've tried recreating the basic shape using masks in AE and then extruding in a custom layer in E3D but the mask intersects are showing as holes in the extrusion.
Changing the mask mode doesn't do anything.
Anyone know a way to combine the masks so I just get the outline? either in photoshop or AE. (I'm thinking this would all be easier in Illustrator but the computer I'm on doesn't have it installed)
Note: I can't go around the image with the pen tool as it isn't precise enough.
Any help would be fantastic!
M
Michael Lansdell
Re: Combining masks for element 3D extrusion
on Oct 22, 2014 at 11:18:17 am
I'm having the same problem, did you ever solve this?
