GTX 770 : GPU and cuda not active in AE CS6
Thierry Lombry
on Mar 26, 2014 at 9:10:29 pm
I use a PC under Windows 7 with a nVidia GTX 770 GC with 4 MB VRAM and an Intel i7 CPU (4 processeurs, 8 threads).
All is fine except that in AE CS6 I cannot activate the CUDA for ray-tracing.
This option is in Menu Edit > Preferences > Previews
then on top right push on "GPU information..." button.
Usually displayed settings are next:
Ray-tracing : CPU
(GPU not available - incompatible device or display driver)
I found on the web that we can edit the AE file "raytracer_supported_cards.txt" located in AE program directory, and add the line "GeForce GTX 770" but it failed with an error (not blocking) in loaded AE, so I removed it.
But adding that line, in AE Edit > Preferences > Previews, I can well select the GPU and the Cuda is activated.
But due to the error at loading I removed the reference to GTX 770 in txt file.
Question:
I have the latest drive for GTX 770. How to proceed to activate the Cuda is AE CS6 without error ?
Thanks.
NB. I have not store it in the default Adobe folder but in another one (I edited the txt file accordingly)
Todd Kopriva
Re: GTX 770 : GPU and cuda not active in AE CS6
on Mar 26, 2014 at 9:32:49 pm
That GPU was added in After Effects CC (12.1):
http://blogs.adobe.com/aftereffects/2013/09/gpu-changes-for-cuda-and-opengl...
After Effects team blog
Thierry Lombry
on Mar 26, 2014 at 9:36:53 pm
You mean that there is NO solution for CS6 ?
What do users who do not want upgrade to CC ? They remain stuck with their issue although they paid the high price ? :-(
I found something that you should know if you work for Adobe
https://developer.nvidia.com/cuda-downloads?sid=471928
I need the confirmation from Adobe that this fix resolves the problem on AE CS6 as at first sight it does not with my configuration.
Roland R. Kahlenberg
on Mar 27, 2014 at 12:27:36 pm
Hi Thierry, I doubt that editing/hacking the "raytracer_supported_cards.txt" is supported or encouraged by Adobe. I think you should check further, on the Web, to see what other users with your GPU have experienced.
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Adobe After Effects CC ACE/ACI
Imagineer Systems (mocha) Certified Instructor
Thierry Lombry
on Mar 27, 2014 at 10:19:47 pm
I contacted nVidia Support about my issue with GTX 770.
nVidia support recommend either upgrade to AE CC or from AE CS6 v11.0 to v11.0.4 as explained here :
http://blogs.adobe.com/aftereffects/2012/05/after-effects-cs6-11-0-1-update...
Then I edited the supported_card.txt file as nVidia suggested and added a line GeForce GTX 770.
I launched AE. In Edit > Preferencec > Previews, the GPU was available and cuda found all the VRAM.
This upgrade resolved the GPU/Cuda issue (without error, and it run up to 6 times faster in rendering).
on Mar 28, 2014 at 12:30:44 am
I'm glad you've sorted out your issue AND reported back.
I was going to suggest hacking the Prefs.txt which MAY remove the error message but I first wanted to see what you managed to source from the Web.
Cheers
RoRK
