c4d multiple files which render?
Hamid Rohi-Bilverdy
on Mar 26, 2014 at 6:10:54 pm
Hi.
Using cineware and duplicating a couple of the c4d project file to incoorporate multipass. What happends when you have 4 c4d files, 3 of them are set to standard draft, the last one which is also the top layer if that one is in standard full what happends to the renders? ?
Hope you undetstand.
Dave LaRonde
Re: c4d multiple files which render?
on Mar 26, 2014 at 7:02:11 pm
I suppose it all depends on what happens next in your workflow.
Is this just for viewing? No big deal.
Is this for final delivery? Replace those drafts with better-quality files.
Dave LaRonde
Promotion Producer
Walter Soyka
on Mar 26, 2014 at 9:31:27 pm
[Hamid Rohi-Bilverdy] "Using cineware and duplicating a couple of the c4d project file to incoorporate multipass. What happends when you have 4 c4d files, 3 of them are set to standard draft, the last one which is also the top layer if that one is in standard full what happends to the renders? ?"
Each layer is independent. Changing one to final does not change them all.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
