AE Pro Import Not Working Properly
Ken Evans
on Mar 23, 2014 at 12:22:35 pm
I'm trying to transfer an edit for FX work from Avid MC7.0.2 to AE CS6. I've followed the Kevin McAuliffe tute word for word but it just doesn't work.
I have an Avid timeline of AMA material, consolidated to MXF wrappers with 2 second handles. I then export this new consolidated timeline to AAF which all goes well.
I then open AE, go to Pro Import and select the AAF file. I use the Quicktime reference and then tick the flatten files box as Kevin does. When the project opens it just has all the clips in a comp with each clip saying 'unsupported media'. It has actually generated a hundred or so clips with that message on it in a folder where the AAF files lives.
I tried some other options like link straight to Avid files but then the project consists totally of all the clips as black solids! No matter what I do I cannot get this sequence to open in AE. Any ideas?
I'm using an iMac at the moment but the project bounces from here to a Mac Pro at work. OSX 10.7.5. Doesn't seem hardware related.
Senior Technician, Moving Image Department - Kingston University London.
Ken Evans
Re: AE Pro Import Not Working Properly
on Mar 23, 2014 at 10:08:02 pm
After the best part of a day I found the problem. Consolidating the material was the wrong move. I transcoded it instead, using a dnxhd codec and it went through fine but creating the AE project took some time. The original material was prores HQ and the AE pro import just didn't like it.
