De Interlace to match Premiere
Paul Kozinski
on Mar 20, 2014 at 11:54:25 am
Hi chaps,
I've deinterlaced all my footage in PREMIERE PRO CC using Field Options>Always DeInterlace, but there are a few clips in my timeline that are After Effects CC Comps.
I've went into the comps and added the Reduce Interlace Flicker effect to the video - but does anyone know what I should set the softness to to match the deinterlace level in Premiere?
Chris Wright
Re: De Interlace to match Premiere
on Mar 21, 2014 at 1:25:02 pm
Reduce Interlace Flicker just blur small details, doesn't deinterlace.
you render out AE with fields off to deinterlace. and make sure that interpret fields for video is uppper/lower/pulldown correctly first.
if you want higher quality, I recommend plugins that preserver detail better than the default adobe settings.
Paul Kozinski
on Mar 24, 2014 at 9:24:40 am
Brillian - thank you, I'll give that a go :)
Chris Wright
on Mar 24, 2014 at 10:37:20 pm
also in AE, if you select preserve details,the deinterlace may look better
