Key Frame Time Setting not showing
Joey Lopez
on Mar 19, 2014 at 12:06:44 am
Hi :D i'm having this probelm with getting my times to show up so i can make animatons to it. If your use to doing this sort of stuff, you know what i mean. Hears a picture of what i am missing
let me know if you can help me out on what i need to do to get these back! Thanks everyone!
I know its a short command and i found how to do it a couple of months ago, but when i google it, i cant find any answers... D:
Roland R. Kahlenberg
Re: Key Frame Time Setting not showing
on Mar 19, 2014 at 4:25:23 am
AE's Timeline is customizable in terms of what you see. That area you circled is known as the Switches column. It is there by default. You or someone else must have inadvertently set it to not be displayed.
To get display the Timeline's Switches panel, right click on any column header in the Timeline and go through the menu that appears after you right click. Select Switches. If that doesn't work then click on the left-most (from a set of three icons) icon at the bottom-left of your Timeline.
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Walter Soyka
on Mar 19, 2014 at 5:44:06 am
The keyboard shortcut to toggle the switches/modes columns is F4, and the shortcut to toggle the parent column is Shift+F4.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
on Mar 20, 2014 at 2:06:24 am
Thanks Walter. I had forgotten to mention those shortcuts - very useful!
HTH
RoRK
