Mocha Pro - Imported footage dimensions
Colin Smith
on Mar 17, 2014 at 10:10:45 am
I've use Mocha for a few years now, but this is the first time i'm stumped on finding a solution for a problem.
I import my shot which is a 2560 x 1350 DNxHD .mov, fine so far. But then when it appears in the mocha tracking window, it displays a 1920 x 1080 cropped version of my footage. I have tried to manually change the dimensions to see the full image but it won't allow me to?
Any suggestions? (in the meantime i'll encode my shot as a different codec and see if that helps).
thanks
Mr S.
Roland R. Kahlenberg
Re: Mocha Pro - Imported footage dimensions
on Mar 17, 2014 at 4:55:39 pm
My thoughts are that the CODEC you're using has been wired in mocha to only work with specified resolutions. An image sequence should overcome such an issue.
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Tero Ahlfors
on Mar 17, 2014 at 7:39:17 pm
[Colin Smith] "2560 x 1350 DNxHD"
IIRC DNxHD only supports the codec setting you give it when exporting although you can enter some other values in resolution. The resolution options are 1280x720 and 1920x1080.
John-Paul Smith
on Mar 18, 2014 at 2:56:02 pm
Hi Colin,
Are you on Windows or Mac? Does this movie open at the correct size in QuickTime Player 7? What version of the DNxHD codecs do you have installed?
One of our developers is working on a number of codec-related issues at the moment so if this is a bug in mocha I will raise it with him.
J-P
John-Paul Smith | CEO | Imagineer Systems
http://www.imagineersystems.com
Colin J Smith
on Mar 19, 2014 at 4:59:28 pm
Hi J-P
I'm on Windows 7 64bit Pro, the footage opens fine in QT 7.7.4, the footage is a downsized 4K Red shot to a 2560 x 1350 ffmbc DNxHD 185Mbit 25fps interlaced pal Mov container.
regards
C
Ross Shain
on Mar 18, 2014 at 2:56:48 pm
I do not know if we have tested 2K DNX files, so you "may" have to convert to image sequence.
Can you please contact support@imagineersystems.com?
We would like to get a test file from you.
Ross
Ross Shain
Imagineer Systems
Tero Ahlfors
on Mar 18, 2014 at 5:00:11 pm
[Ross Shain] "I do not know if we have tested 2K DNX files"
The thing is is there even 2K DNxHD because at least in Adobeland the Quicktime codec is locked to the codec settings. You can only make what is available under the codec's settings and those are 720i/p and 1080i/p in different framerates.
edit: Pages 9-10 http://www.avid.com/static/resources/US/documents/dnxhd.pdf
on Mar 18, 2014 at 8:06:31 pm
I too doubt that DNxHD works in non-HD formats, ie SD and ultraHD formats AND it's well-known that Avid CODECs allows the user to select 'strange' resolutions for export/render even though the exported/rendered will be conformed to the CODEC's supported resolutions.
HTH
RoRK
Colin J Smith
on Mar 19, 2014 at 5:17:35 pm
Thanks Ross,
Email sent.
regards
C
