AFter Effects error: Can't overwrite file
Joey Sperber
on Mar 17, 2014 at 1:27:28 am
Hi, I recently updated to a mac pro and used my backups from my old computer to put on the new one. Now whenever I open up a old AE file or try to use dynamic link with Premiere Pro I get the message
After Effects error: Can't Overwrite file "/Users/joey/Library/Preferences/Adobe/After Effects/11.0/Adobe After Effects 11.0-x64 Prefs
The problem is that I can't even find that file on my hard drive, any idea what happened
Joey
Roland R. Kahlenberg
Re: AFter Effects error: Can't overwrite file
on Mar 17, 2014 at 5:13:52 pm
No idea what the issue is but you can find the Prefs File via AE's Preferences dialog window. In this window, at the bottom left, is a button that sends you to the OS and selects the Prefs file.
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Walter Soyka
on Mar 17, 2014 at 7:05:01 pm
Mac OS now hides your Library folder. Here are 19 different ways to get to that folder on Lion and up:
http://www.macworld.com/article/1161156/view_library_folder_in_lion.html
Easiest way: go to Finder, press Cmd+Shift+G (for Go to Folder) and enter:
~/Library/Preferences/Adobe/After Effects/
Select the 11.0 folder and press Cmd+I (for Get Info). You may need to click the lock button in the lower right corner and enter your password to allow yourself to make changes. Make sure that the folder is set "Read & write" and also click the gear button and choose "Apply to enclosed items."
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Daniel Ziegler
on Jul 14, 2014 at 5:42:12 pm
Walter - Thanks so much. You just saved my A. BTW, it works for AE 10.0 as well.
Henry Lee
on May 18, 2015 at 12:37:32 pm
Yes! Your read/write issue solved mine too! Thanks.
Ot Crozz
on Mar 26, 2016 at 12:37:22 am
WOW! Thank you for your post. I had the same issue(s).
Jack of all trades - Want to master them ALL. Yup you guessed it... I'm a pre-press artist.
Todd Kopriva
on Mar 17, 2014 at 11:14:31 pm
For details about what's going wrong here, see the last section of this article:
http://blogs.adobe.com/aftereffects/2014/01/known-issues-workarounds-after-...
After Effects team blog
