How to lock z position?
Kim Bo
on Mar 10, 2014 at 9:45:35 pm
I'm searching how to lock the Z position, and being able to move the X and Y position?
Dave LaRonde
Re: How to lock z position?
on Mar 10, 2014 at 10:33:30 pm
If you don't need 3D, just work in a 2d environment and you won't have to worry about it.
Dave LaRonde
Promotion Producer
Kim Bo
on Mar 10, 2014 at 10:37:23 pm
I'm using 3D, but I don't want to move the Z... only the X and Y
Dave LaRonde
on Mar 10, 2014 at 11:01:34 pm
You can separate the x, y & z-axes -- there's a command for that -- and then use the simplest of expressions on the z-value: the numeric value you want. That'll give you a constant z-value.
Dave LaRonde
Promotion Producer
Kim Bo
on Mar 10, 2014 at 11:05:16 pm
I already try... but when I move my image on the viewer directly, well it moves my Z axe as well... that's why I was wondering if there is a way to lock it
Roland R. Kahlenberg
on Mar 11, 2014 at 10:15:09 am
An Expression for the layer's position property like this should work -
[value[0], value[1], 0]
Just replace the 0 with the value you want for the Z-position.
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
