Best way to Batch Process video dimension by 50%
Richard Shearman
on Mar 5, 2014 at 3:07:53 pm
I have 150 video files (1440 x 1080) and all are 10 seconds duration.
Is there a program where I can quickly do the following:
Open each file
Resize by 50%
Possibly loop the clip 20 times
Export to a new video file
If not, how would you best go about this process?
Thank you in advance.
Regards,
Richard.
Gary Noden
Re: Best way to Batch Process video dimension by 50%
on Mar 5, 2014 at 3:13:50 pm
Adobe Media Encoder Watch Folders.
You drop your file into the Media Encoder watch folder which you previously set up convert whatever goes into a your resolution parameters and file format and it just does it, putting the original in a subfolder called Source.
It's amazing
Richard Shearman
on Mar 5, 2014 at 3:25:20 pm
Great, thanks. Will check that out later.
Will it also do the loop repeat?
timo santiago
on Mar 6, 2014 at 11:10:35 am
lazo the red
John Cuevas
on Mar 5, 2014 at 4:43:47 pm
To loop the videos, you could bring them into AE, click interpret footage(left click the video+) and change the loop to 20. Now press "cntl+alt+c" to remember the interpretation, select all the videos you need to loop 20 times and press "cntl+alt+v" to paste it. Drag all your videos on to the make new comp button and select "add to render queue, and set up a templates to create your new videos.
Or you could drag all the comps into Media Encoder and do the work in there.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
