Only 4% of 64GB RAM being used?
Olly Lawer
on Mar 5, 2014 at 9:49:24 am
We have a new machine.
Case: "E-Series" E200IBE Midi Case (Supermicro® CSE-732D4F-903B) - 900W PSU (No Hotswap)
Mainboard: Supermicro® X9DAi Mainboard (16x DIMM Slots)
Graphics Card(s): NVIDIA GeForce GTX 780 - 3GB (PCI-E 3.0) - (2304 GPU Cores)
Hard Drive (1): PNY 480GB Previal 3k Endurance Series - SATA-III - SSD
Hard Drive (2): Intel® "Dale Crest - 530"- 240GB - SATA3 - SSD (AE SCRATCH EXCLUSIVE)
CPU(s): 2x Intel® Xeon® Processor E5-2650v2 (8x 2.60GHz / 20MB) [w/ HT]
Memory: 64GB DDR-3 1866MHz - ECC Registered (PC3-15000) RAM
It is slower than we thought it would be. Compariable to our iMac 2012, 32GB RAM, i7.
We have 29 cores running at 2GB (tried 3GB and less cores, but same result). We have enabled the GPU (although had a warning about it being untested and possibly unreliable).
RAM preview is a smidgen quicker, but the render is quite slow and says that AE is only using 4% of the RAM.
Any ideas?
Olly Lawer
Walter Soyka
Re: Only 4% of 64GB RAM being used?
on Mar 5, 2014 at 10:53:50 am
Open Task Manager (Ctrl+Shift+Esc) and click the Performance tab. Please take a screen shot of this while rendering.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Jason Jantzen
on Mar 6, 2014 at 3:40:40 pm
Watch this. There are some tips in there for optimizing your multiprocessor settings. It will take some testing, but ideally, when you multiprocess, you only want AE to use as many physical cores as you have installed. In your case: 16. So set the allocated RAM until you're only using 16 CPUS (there might be a few, hence the testing) and then start testing to see which is the fastest render.
Jason Jantzen
vimeo.com/jasonj
Olly Lawer
on Mar 7, 2014 at 9:22:13 am
Thank you. this was very useful! I always thought it was a good idea to use the virtual cores!! Have now allocated 16 of the 32 cores to other applications. In fact, I bumped the RAM up per core to 4GB so it only uses 14 cores as this surely should be quicker. Alas, it still isn't that quick...
Here is a screenshot as requested.
Olly Lawer
Olly Lawer
on Mar 7, 2014 at 9:31:12 am
This is probably useful too.
First pic: 14 'real' cores at 4GB per core:
Second pic: 29 cores at 2GB per code:
Not much difference really.
Olly Lawer
