CS6 Problem with Expressions Char Array and Time
Diego Mellado
on Mar 3, 2014 at 5:52:34 pm
Dear all,
I am using CS6 (11.04 update) and I can not explain what is happening.
I am using this expression for opacity:
ch1 = thisLayer.name[0];
ch2 = thisComp.layer(1).name[(Math.round(time))];
if (ch1 == ch2) o = 100;
else o = 0;
o
The layer name has one char an the comp name has 5 chars.
If it set the time to 0:00:00, and I evaluate the expression, I have this error:
After Effects warning: Class 'TextProperty' has no property or method named '7'. Expression disabled.
It seems like it is trying to access to the pos 7 of the char array of thisComp.name[] but at time 0:00:00 this makes no sense..
I have tried the very same expression (copy&paste) in CS5 and works perfectly.
I have attached both projects for testing.
Can somebody please tell me why? This is driving me crazy...
Best,
Diego
Diego Mellado
Re: CS6 Problem with Expressions Char Array and Time
on Mar 3, 2014 at 6:04:24 pm
Here it its the CS5 Version of the Test
7186_cs5test.aep.zip
An here it is the CS6 Version of the Test
7188_cs6test.aep.zip
Best,
Diego
