Rotating two objects
Jack Johnson
on Feb 28, 2014 at 12:09:39 am
I have two half-circles that I have positioned as a circle. I'm trying to have the circle as a whole rotate around over time. There is an effect for this, but instead of rotating the two layers as a whole it rotates them individually. My question would be how I can make them rotate together or change the center rotation point?
John Cuevas
Re: Rotating two objects
on Feb 28, 2014 at 1:11:26 am
Add a null and place it in the center of both half circles. Parent the circles to the null and then rotate the null.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
