Ninja Impact Bomb with Particular
Dan Donaldson
on Feb 27, 2014 at 9:34:02 pm
Hey guys,
I've been working on this project in my spare time. It's a visual manual of skills needed to be a ninja (assassination, infiltration, deception, etc). Anyway, I've been trying to make an impact bomb using Particular but I've hit a wall. I've tried a couple of things using wind but I can't replicate the quick explosion of smoke to a slow rise upwards. Any suggestions would be appreciated!
Mike Sevigny
Re: Ninja Impact Bomb with Particular
on Feb 27, 2014 at 9:56:04 pm
1. Under the 'Physics' tab you'll find 'gravity', set it to a negative number, that will give you the slow rise.
2. For the quick burst use the 'velocity' under the 'Emitter' tab at the same time as 'air resistance' under 'Physics'.
Mike Sevigny
John Cuevas
on Feb 27, 2014 at 11:03:31 pm
Peder Norby made this project 10 years ago to show off Particular, fireworks, smoke text. I think you might be able to modify the "Smart Bomb CCD" project to create what you need.
7168_pyropackcs6.aep.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
