Color Swatch Window, does this functionality exist or is it a feature request?
John Cuevas
on Feb 26, 2014 at 1:15:08 pm
Different clients have different palettes and I often end up making a pre-comp with all there colors and dropping it into my master comps and make it a guide layer. It would be nice to have a dockable color swatch window like illustrator where I could save/load different clients color palettes, right in AE.
So is there a way to do this, does it exist as a script somewhere, or is this something I should ask Adobe to put on there to do list?
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Walter Soyka
Re: Color Swatch Window, does this functionality exist or is it a feature request?
on Feb 26, 2014 at 1:23:21 pm
You have a couple script options:
http://aescripts.com/chameleon/
http://aescripts.com/colorlibrary/
But this is also a good feature request nonetheless.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Walter Soyka
on Feb 26, 2014 at 1:26:16 pm
I should add: I often create a composition named Palette with a null layer named Palette, and drag Color Control effects onto it. I open a new, locked effects control panel for Palette:Palette and dock it on the screen, and pickwhip colors to the locked and docked Palette ECP.
Walter Soyka
John Cuevas
on Feb 26, 2014 at 2:17:09 pm
Knew somebody must have engineered a solution to this already. Thanks Walter.
Thinkck.com
Ridley Walker
on Feb 27, 2014 at 12:27:45 am
[Walter Soyka] "I should add: I often create a composition named Palette with a null layer named Palette, and drag Color Control effects onto it. I open a new, locked effects control panel for Palette:Palette and dock it on the screen, and pickwhip colors to the locked and docked Palette ECP."
You are a clever man Walter, thanks for the tip.
George Goodman
on Feb 27, 2014 at 3:18:54 pm
Genius Walter!
"|_ (°_0) _|"
Sincerely,
George
