Adobe After Effects CS6- 3D Camera Tracker/ Mocha CS6 Massive Problems
Simon Huang
on Feb 26, 2014 at 11:52:45 am
First of all, I would apologise if this is posted in the wrong section or something. I am new to this site :)
Anways, here's my problem.
I have looked far and wide into the oceans from tutorials to forums etc, but I cannot seem to find the solution to the problem. I am pretty frustrated...
I am using adobe after effects cs6 and I have decided to track my footage with 3D Camera Tracker. However, the mountain in my footage seems to shift back and forth abit. I know it is not a good footage to track as there are a few targets.
please go to the following link.
http://postimg.org/image/wi80qmwwb/
The same thing has also happened with Mocha CS6. I have looked at dozens of tutorials but to no avail. This is what I have done:
I used the "X Spline Layer Tool" and drew around the area that the mountain will appear in.
I then tracked it with the button "track forward". Everything was fine, everything was fully tracked.
I then pressed "Export tracking data"- After Effects Transform data.
In Adobe, I create a "Null". Pasted the tracking data. Unticked "anchor points". Parented the mountain to "null".
However, despite the excellent tracking in Mocha, the mountain still shifted around. I am on the brink of giving up. However, when I use a different element such as a fire, it tracks perfectly.
http://postimg.org/image/qc1x0pbdp/
Sorry, for the lengthy post. Please help. I am even willing to send my project so you professionals can help me out. Any advice/ tips/ or anything would be appreciated.
Roland R. Kahlenberg
Re: Adobe After Effects CS6- 3D Camera Tracker/ Mocha CS6 Massive Problems
on Feb 26, 2014 at 4:00:01 pm
You should track just the horizon - a single plane. Your tracking spline covers two different planes; the horizon and the water.
Track again in mocha but restrict your tracking spline to the edge of the water and include some of the cloud/sky area.
I suggest that you watch the following tutorials as you seem to not understand what planar entails -
Start here - http://www.imagineersystems.com/videos/steve-wright-planar-tracking/view. Then look for the other tutorials in the "Learn mocha" series which were authored by Steve Wright.
Then reinforce what you've learned with these other tutorials -
http://www.imagineersystems.com/videos?tagFilter=Fundamentals+of+mocha&sort...
I'm also surprised that you've successfully linked to another object. There's obviously some difference between these two objects that you've not shared.
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Ross Shain
on Feb 26, 2014 at 5:25:26 pm
Yes - as Roland suggests, you need to track 1 plane in mocha. The water is obviously moving on a different plane than the clouds in the background and will throw off your track.
I would suggest tracking just the clouds in a smaller shape if you are trying to do sky replacement.
mocha V3 has a 3D solver in which the user tracks multiple planes, than does a camera solve on the selected planes, but first you need to get a good grasp of how planar tracking works.
Best,
Ross
Ross Shain
Imagineer Systems
Simon Huang
on Feb 27, 2014 at 9:37:02 am
Thanks for the reply. I'll give it a try. But, how do you differentiate one plane from the another? I thought you simply create a spline or a box around the area, and place the mountain in the area that you tracked in Mocha.
on Feb 27, 2014 at 1:24:03 pm
[Simon Huang] "But, how do you differentiate one plane from the another?"
Your question is incredibly basic - it is something you should know prior to tracking with mocha. You were provided with a couple of URLs to help you in this area. Please do the neccesary.
HTH
RoRK
