After Effects and Premiere cs5 Dynamic Link Sync Issue
Anthony Imperioli
on Feb 26, 2014 at 2:23:41 am
Hello ladies and gentlemen,
First time posting on here so I hope I'm doing this right in terms of etiquette. I've searched and have not found a solution to an odd problem I seem to be having when using Dynamic Link with Premiere and After Effects.
Essentially what happens is when I go into After Effects and do my comp and everything associated to it - when I return to Premiere it's out of sync. For example: I have a mask that I use around a character's hand. In After Effects it works fine - in Premiere it's a frame off. I also notice that Premiere HOLDS a frame at the beginning of the clip on every clip that I've 'replaced with an After Effects' composition.
I've check the frame rates and everything seems to be correct. Not sure where the problem might stem from but I do know this isn't the first time I've encountered this.
Any help is greatly appreciated!
© 2018 All Rights Reserved
