Mocha shape points data
Marc Lucas
on Feb 25, 2014 at 3:14:50 pm
I tracked a finger in Mocha and exported the shape data and when I imported into AE I got what I wanted an outline of the pints so I could adjust to taste seen here https://dl.dropboxusercontent.com/u/2003727/Finger1.png
I then did the same shape data export and got the shape data but there wasn't tracks points visible in AE when in the canvas like the in the pic above.
Ross Shain
Re: Mocha shape points data
on Feb 25, 2014 at 6:05:12 pm
When you paste from mocha AE to After Effects there are 2 options:
Paste> Will paste the mocha shape plug-in. The mask handles are not visible BUT the variable feathering from mocha AE is supported.
Paste>paste mocha mask Will convert the mocha shape data to AE masks, so you will see the mask tool itself.
Ross Shain
Imagineer Systems
http://www.imagineersystems.com
Marc Lucas
on Feb 25, 2014 at 9:49:53 pm
Thanks I got there a while ago.
Thanks for the reply!
Marc Lucas
on Mar 10, 2014 at 12:31:40 pm
Hi Ross
I've stumbled on this again I have tracked the 'finger' in Mocha and exported the Shape Data then selected 'Paste Mocha Mask' and it is doing the exact same as I had before. I'm getting mask Path Key Frames but can't see them in the Canvas.
https://www.dropbox.com/s/80b66ci2sqg4pzu/Screen%20Shot%202014-03-10%20at%2...
