Iff sequence problem
john titor
on Feb 23, 2014 at 10:39:58 pm
Hi, I have an .iff image which I want to apply directional blur to and when I render it out as an .iff sequence the sequence itself is shorter than the original duration of the image in the AE project. It's like it's moving at a slightly faster frame rate as when I match it up it goes out of sync at a later point in the timeline. I've checked that the frame rate matches the frame rate in the comp settings. Is there any way to solve this?
