Make video more jitterish
David Garcia
on Feb 22, 2014 at 7:57:28 pm
I want to create a different look to my film. Like this one?
https://vimeo.com/32999037
Any idea how he does it? High shutter speed and then slowed down?
It seems almost as if frames are skipped.
Any help would be helpful
Todd Kopriva
Re: Make video more jitterish
on Feb 23, 2014 at 4:00:07 pm
Create a composition with a low frame rate. Nest the composition containing your footage layers in this lower-frame-rate composition.
Or, you can use the Posterize Time effect, which is a bit simpler but a lower-performance method.
Details here:
http://helpx.adobe.com/after-effects/using/time-effects.html#posterize_time...
After Effects team blog
David Garcia
on Feb 23, 2014 at 4:07:34 pm
Thanks a lot.
It sounds like it is what Im after. Will try it!
