Copy text perimeters from one text layer to multiple others?
Michael Garske
on Feb 21, 2014 at 7:26:56 pm
I need to change settings that are in the character panel on several text layers at once (Baseline shift, kerning, size, etc...). Is there an easy way to copy these character settings from one layer to another? Thanks!
John Cuevas
Re: Copy text perimeters from one text layer to multiple others?
on Feb 21, 2014 at 7:55:07 pm
This script is the only way I know of doing it for a lot of text at once. textEdit
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Anders Hattne
on Feb 21, 2014 at 11:12:48 pm
Have you tried selecting all the text layers and adjusting the parameters?
It's not copying but, all layers will end up having the same parameters... or did I missunderstand this completly?
http://www.ardillamedia.com
Michael Garske
on Mar 15, 2014 at 6:12:04 pm
Sorry I let this one go for a while. The textEdit script did the trick! Many thanks!
