Can I attach a null object to text edge?
Dmitry Yershov
on Feb 21, 2014 at 1:38:06 pm
Hey everyone,
Is it possible to attach a null object to the edge of the text in order for the Null's position to respond to the number of characters in the placeholder?
So if I change the length of the text the null stays at the edge of the last character?
John Cuevas
Re: Can I attach a null object to text edge?
on Feb 21, 2014 at 5:34:16 pm
Probably need an expression to accomplish that, try posting in the AE Expressions Forum
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Kevin Camp
on Feb 21, 2014 at 11:44:19 pm
not really...
if you happen to use a fixed width font (like courier), you could use an expression that counted the number of characters and multiplied it by the width of a single character (you'd need to determine the width of a single character). that expression would look something like this:
target = thisComp.layer("MyText"); // this would be your text layer
w = 25; // set the width for a single character in pixels
offset = target.text.sourceText.length * w
value + [offset,0]
move the null to the end a the text and then apply that expression (changing the target layer to be your text layer and the setting w to the width of a single character) and it should follow the end of the text string if you use a fixed width font.
if you are not using a fixed width font, then it would difficult.
what is it that you are ultimately trying to achieve?
Kevin Camp
Art Director
KCPQ, KZJO & KRCW
Dmitry Yershov
on Feb 22, 2014 at 12:07:59 pm
Thanks a lot, Kevin!
