Split single clip into two using masking
Jared Snyder
on Feb 21, 2014 at 7:53:14 am
I have a sunrise clip. The sunrise is in real-time and quite slow, so I want to speed it up. However, if I just speed up the clip, the ocean tide will speed up too, which I don't want to happen. What is the best way to go about splitting the clip into two separate pre-comps, so I can do a time compression on the sunrise without effecting the ocean tide? Thanks!
Roland R. Kahlenberg
Re: Split single clip into two using masking
on Feb 21, 2014 at 10:52:53 am
Lots of options - masks, RotoBrush, keying, AutoTrace, mattes or a combination of the above. It all depends on the footage you're dealing with.
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
