Form grid not perfect
Chris McCard
on Feb 21, 2014 at 12:56:08 am
Anyone here ever tried layering form over form grid at a smaller size?
I'm experiencing some weird issues, I'm pretty sure I did the math correctly and it should be lining up however I'm banging my head against the wall trying to figure this out.
Heres my setup, I have 2 layers each with form on them
one of them is
10000px X 10000px with 500x500 particles
and the other is
2000px X 2000px with 100x100 particles -
the math all seems right to me and it should be lining up on top of eachother, but its not. it seems to start separating out of the middle. and becoming offset. Dont know if this all makes sense, heres a screeenshot to see whats going on.
Roland R. Kahlenberg
Re: Form grid not perfect
on Feb 21, 2014 at 11:09:13 am
What are you intending to do with the grid or with the objects in the grid? There are other options to creating a grid.
HTH
RoRK
Latest AE Workshop - MoGraph Intensity - Shapes & Text
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects CS6 ACE/ACI
Darby Edelen
on Feb 21, 2014 at 12:10:52 pm
[Chris McCard] "Heres my setup, I have 2 layers each with form on them
one of them is
and the other is
the math all seems right to me and it should be lining up on top of eachother, but its not."
The spacing of the grid is what's causing this. The particles at the edges of the grid will have their centers located at the boundary of the grid. To account for this you can modify your grid sizes.
Simply take the value you currently have and subtract Particle Size * 2 from both the large and small grids, so if you had a particle of size 10:
2000 - (2 * 10) = 1980
10000 - (2 * 10) = 9980
Those sizes will cause the particles to line up entirely inside of a 2000x2000 and a 10000x10000 grid instead of the outer particles sitting half inside and half outside those boundaries.
Darby Edelen
on Feb 21, 2014 at 2:59:45 pm
Darby's likely got the math correct but my thoughts are that you could easily have duplicated the larger layer and then applied a track matte to delimit its effective size.
HTH
RoRK
Chris McCard
on Feb 21, 2014 at 5:23:10 pm
Yea, ive experimented with a few other ways of making grids, however the form way is how i decided to go as I'm going to be flying around this grid a bit- and the smaller grids that are inside of that I'm using for pattern generators to effect the color/opacity of only whats inside that area. There may be better ways to do this, but form was my first setup on it and i thought it would work best.
Chris McCard
on Feb 21, 2014 at 5:19:55 pm
This works great! thanks for your help. i was sorta eyeballing it before hand but the math really helps on this. Thanks so much!
