Out of memory error
Jon Doughtie
Out of memory error
on Feb 17, 2014 at 10:02:13 pm
One of my folks is getting an "Out of memory: requesting 1k 23: 40" error message working in After Effects.
It's not a particularly involved comp.
Specs:
AE CS6
Win 7 Enterprise (8 core)
8GB
1.5GB RAM reserved for other apps
plenty of hard disc space
Recent change: Installed Red Giant Free Quicklooks. It is being used in the project.
I know memory is low. I had him move the project from his desktop to one of our regular systems with Adobe AE CC and 32GB RAM; the error persists.
Corrupted project file?? The error first appeared when he added a text layer and was typing. An issue with the Red Giant plugin?
Dave LaRonde
Re: Out of memory error
on Feb 17, 2014 at 10:34:00 pm
If you suspect the plugin, you can try this: duplicate the project, confirm that the problem also exists in the duplicate, then remove the instances where the plugin is applied in it. If the problem goes away, you've isolated it.
Dave LaRonde
Promotion Producer
Jon Doughtie
on Feb 18, 2014 at 1:57:27 pm
Removing the Red Giant Quicklooks made no difference.
It appears we have isolated it to one layer with a PSD file. When that layer is switched off, the error disappears. Switched on, the error promptly reappears.
We have tried flattening the PSD to a PNG, also tried reducing size. No change. There's nothing unusual about the file. It has transparency, it is set for and RGB/8bit colorspace.
We are just stumped.
Jon Doughtie
on Feb 18, 2014 at 2:01:21 pm
JUST FOUND THE ISSUE.
The layer has three effects on it, including the puppet tool. As soon as puppet tool is switched off, the issue disappears. So the puppet work will be discarded and redone.
Walter Soyka
on Feb 18, 2014 at 3:33:18 pm
Jon, thanks for posting back with the solution! I wish everyone were as conscientious as you.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
