How do i convert a 1280X720 size Template into DV PAL
Chandrasekhar Pendiala
on Feb 15, 2014 at 6:51:37 am
I have recently downloaded a template with 1280X720 dimensions. But i want to convert that template into DV PAL (standard size)... Could please let me know how do i do it with changing much of the settings...
Regards,
Sekhar
Dave LaRonde
Re: How do i convert a 1280X720 size Template into DV PAL
on Feb 15, 2014 at 6:12:12 pm
What is the frame rate of the template?
If it's 25fps, do all your work in the template. Then nest it in a DV PAL widescreen comp. Scale the nested comp to fit the new comp. Done.
Dave LaRonde
Promotion Producer
