How to KEEP Transparency Grid in After Effects CS6 Export
maritza garcia
on Feb 14, 2014 at 7:17:00 pm
Hey guys i need help,
I want to keep my transparency grid in my after effects export because i like the look of the grey checkered boxes .. i've tried exporting with lossless thinking it would keep the transparency grid in the final output but it didn't work just gives me a solid black background! lossless + alpha will make my footage completely transparent but thats not what i want.
Any suggestions?
Ridley Walker
Re: How to KEEP Transparency Grid in After Effects CS6 Export
on Feb 14, 2014 at 7:40:54 pm
You could do a screen grab of the grid and composite this as the background layer.
maritza garcia
on Feb 14, 2014 at 8:02:15 pm
Yeah that works.. But I want to know if there's a way to do this in AE without having to do a screen grab of the grid.
Thank you!
John Cuevas
on Feb 14, 2014 at 8:16:27 pm
The grid is for reference only, like a guide layer, it doesn't show up in renders. If you like that as a background, use the Effect Generate > Checkerboard and mimic the grid. In a 1280x720 comp, I set the Width to 8, Color to 178,178,178 and the blending mode to "Normal"
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
maritza garcia
on Feb 14, 2014 at 8:27:06 pm
Cool thanks I'll try it.
