Render on transparent, using "Drop Shadow" pretty please
Ellen Pollard
on Feb 11, 2014 at 10:59:06 am
Hello dear after effects experts!
I need to make subtitles for an animation.
To make them easy to read, I use the layer style "Drop shadow".
When I render on transparent, quicktime, animation codec, "RGB + Alpha", it doesn't work :(
Without the layer style it works perfectly.
Please please help me with a solution :)
Thanks! Ellen
Walter Soyka
Re: Render on transparent, using "Drop Shadow" pretty please
on Feb 11, 2014 at 1:58:21 pm
What do you mean by "it doesn't work?"
Can you describe exactly what steps you're taking, what you expect to see, and what you're actually seeing?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
John Cuevas
on Feb 11, 2014 at 3:07:46 pm
I just created one and it worked fine, where isn't it working for you, in an NLE? Have you tried importing the graphic back into AE and checking there---cause some NLE's can be finicky about how you bring in alpha's.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ellen Pollard
on Feb 11, 2014 at 3:12:57 pm
Hello all!
Thank you so much for the responds.
There is one episode in which it wouldn't work.. As soon as I tried it in the other ones it was fine with codec "animation" and RGB+Alpha.
So just made the first one again.
tsss computers ;)
Dave LaRonde
on Feb 12, 2014 at 1:08:56 am
You said "layer style". Don't use the drop shadow layer style. Ijnstead, use the Drop Shado effect in AE.
Dave LaRonde
Promotion Producer
