New comp for After effect cs6?
Hamid Rohi-Bilverdy
on Feb 7, 2014 at 7:54:42 pm
Hi
I want to upgrade my after effect cs4 to AE CS6, and with that I want to buy a new computer. With that I have a few questions.
I will mainly be using it for short clips in full HD, and combined with some 3D from Element3D.
Computer specs:
CPU: Intel Core i7-4771 4x3.50GHz (Turbo 3.90GHz)
RAM: Kingston 32GB DDR3-1600 HyperX RAM
Grafic card:Asus GeForce GTX650 2GB
HDD: 250GB SSD (Samsung 840 EVO)
HDD: 1TB 7200rpm Seagate
OS: Windows 7 Ultimate
How many ram of the 32 can i use with cs6 spread out to the 4 cores?
Is the grafic card suitable??
Regards HRB
Dave LaRonde
Re: New comp for After effect cs6?
on Feb 9, 2014 at 10:58:13 pm
I doubt you will use the new machine for After Effects ONLY. What other applications will it run?
Dave LaRonde
Promotion Producer
Hamid Rohi-Bilverdy
on Feb 10, 2014 at 4:48:05 pm
Hey Dave.
Other than AE I will be using the comp for Cinema4d, photoshop and ilustrator. I will also connect it to my synology NAS with 4TB harddrive to use it occassionaly as a media server. If the comp can take it ofcourse.
Dave LaRonde
on Feb 10, 2014 at 6:26:36 pm
So this means that you intend to do no video editing -- no FCP, no Avid, no Premiere Pro, no Vegas, etc.
Likewise, there will be no audio editing or audio production done on this machine: no Audition, no Soundtrack Pro, no Pro Tools, etc.
If this is true, I would follow the recommendations in already in this thread.
Dave LaRonde
Promotion Producer
Hamid Rohi-Bilverdy
on Feb 10, 2014 at 7:01:00 pm
Dave. Thanks for pointing it out to be completely accurate. I forgot to mention premiere pro and as for sound nothing in the pro end i have been happy sticking to the outdatet soundbooth.
Jason Jantzen
on Feb 10, 2014 at 3:49:00 pm
On my 6 core, I've got it spread out to using 4gb per core. And quite frankly, AE will be just fine with 32gb of RAM and a 4 core chip if you insist in using the machine while it's rendering.
Jason Jantzen
vimeo.com/jasonj
EricBowen
on Feb 10, 2014 at 6:34:30 pm
The GPU is fine for AE. Only the Ray Tracer components use the GPU. AE will use what ever ram you have available. Definitely get the 32GB.
Eric-ADK
Tech Manager
support@adkvideoediting.com
